A/C thorowing hot air
I have a 04 honda Accord LX V6 summer is coming when i turn on my a/c i just feel hot air before the heat came it threw cold air for a while and then threw hot air can it be that my a/c needs to be re-charge or can there be a leak in the system i touch lower presure line and it was warm wasn't cold like it should be when its running compresure looks like its working. So what can it be?
Re: A/C thorowing hot air
on accords i have done a lot of a/c work. everything from the common hole in the condenser, the semi common reciever dryer coming apart (replacing dryer, condenser and expansion valve and flushing lines) to the rarer a/c compresser lock up and coming apart and doing compressor, clutch, coil, expansion valve, condenser and dryer.
i need pressure numbers to help you any further and amount of charge pulled out.
are you sure the compressor is kicking on? i recently worked on an '05 V6 where the compressor simply won't come on. the owner's original complaint was the same as yours and i changed compressors, but it still won't come on. i'm looking for wiring diagrams as we speak.
nikech1
10-06-2007 04:12 PM
