Blower motor repeated resistor failures
Looking for a little help with my 2004 Accord EX v6 4dr. I am having issues with the Blower motor circuit. I have replaced the resistor twice. The first new resistor ran for about 10 minutes. I ordered a replacement blower motor and another resistor and it again ran for about 10 minutes. The fuses look fine and I've tested the under dash relay as fine as well. I can't locate any noticeable wiring issues with the harnesses. Anyone have any thoughts or suggestions? I've ordered some thermal fuses to repair the existing blown resistors and now have two in working order again. They seem to get very hot very quickly when installed and the blower turned on.
Also is the motor control module built into the climate control unit or is it independent. Thanks in advance!
Sorry if this is covered somewhere already. I've dug through the forums quite a bit and can't seem to locate anything.
Thanks!
J
Thanks!
J
