blower motor issues
Old Oct 29, 2014 | 10:41 AM
tamboo's Avatar
10 Year Member
Default blower motor issues
climate blower motor died but i pulled and tested and it's ok (4 seasons makes awesome motors, at least they did 10 years ago). switched the under hood relays but no dice and fuses are ok. i also get no a/c light when i push the button and the fans dont come on either. a/c refrigerant pressure has been ok all summer.
bad blower motor switch perhaps? but would that cause the a/c issues as well?
i can likely get through the winter by popping the moonroof a bit to pull heat out of the dash but it is puzzling. suggestions?
Old Nov 4, 2014 | 03:14 PM
tamboo's Avatar
10 Year Member
Default Re: blower motor issues
the resistor is the likely suspect according to this:
if so the standard intermotor looks like the way to go:
More Information for STANDARD MOTOR PRODUCTS RU71
Old Nov 4, 2014 | 04:35 PM
fcm's Avatar
fcm
Old Fart
A/C will not work unless blower motor is working.
Blower resistor may be the problem, but you normally get the fast speed only if it is the resistor.
Unplug the blower motor and test for power on the blue/white lead, with ign, switch on.
There are two(2) fuses for the blower relay main power 40A in engine bay fuse box and the switched power 7.5A in under dash fuse box.
If there is power on the blue/white, plug the blower back in and supply a direct ground, [jumper lead] from chassis to the blue/black lead, if blower motor works, the problem must be either the blower resistor or more likely the blower speed switch or wiring to it.94
Old Nov 6, 2014 | 09:13 AM
tamboo's Avatar
10 Year Member
pulled the resistor and tested, got 3.3 ohms instead of 2-3 spec.
standard intermotor unit is on the way, will update next week.
here's a more detailed guide:
Old Nov 11, 2014 | 01:53 PM
tamboo's Avatar
10 Year Member
damn, new resistor did not bring joy. 8(
time to rip into the dash, doesnt look like fun.
Old Nov 11, 2014 | 02:18 PM
tamboo's Avatar
10 Year Member
hmmm rockauto lists a blower switch but it doesnt look the same.
grabbed this as it fits 95 civic and looks proper:
STANDARD MOTOR PRODUCTS Part # HS257
cheapest price i could find and they make good stuff afaik...
Old Nov 12, 2014 | 12:48 AM
KILLAB17VTEC's Avatar
Genetically Gay
Bad motor ac needs recharge
Old Nov 12, 2014 | 04:23 PM
fcm's Avatar
fcm
Old Fart
Have you tried the troubleshooting suggestions I listed?
Tossing parts at a problem is an expensive way to troubleshoot a problem. 94
Old Nov 13, 2014 | 09:50 AM
tamboo's Avatar
10 Year Member
havent tested switch or wiring, everything else is ok.
afaik low a/c pressure wasnt messing with blower when i had that issue.
resistor was out of spec so it needed replacing according to helm.
thing was fillthy with almost all ceramic coating gone.
that was $18 and the blower switch was $10.
how much of your labor would $28 buy mr. fcm?:lol:
Old Nov 16, 2014 | 09:42 AM
fcm's Avatar
fcm
Old Fart
Kind of depend what you think your time is worth, but $28 if you did not need the switch and resistor in the first place, and the labour it took to put them in, if they where not the problem. 94
Old Nov 16, 2014 | 11:57 AM
tamboo's Avatar
10 Year Member
well i'm ok with replacing $20 parts once every 20 years lol.
helm says approx 2-3 ohms for the resistor, i got 3.3 so maybe
it's ok but looks nasty.
getting at that switch doesnt look like fun though.
at highway speeds the sunroof does pull out a decent amount of heat
so i may wait for warmer weather. where are the two grounds located?
Old Nov 17, 2014 | 04:22 PM
fcm's Avatar
fcm
Old Fart
You said everything else is OK, does that mean you have power, [12V+] going to the blower motor, [blue/white]?
If so, supply a ground, [using a jumper lead from chassis] to the blower ground lead, blue/black, if blower works, the problem is either the resistor, the switch, wiring to the resistor or wiring to the switch.
If blower works with ground jumper, pull the HVAC, [heater] control and test the black lead for continuity to ground, if good, use a jumper from the black lead to the blue/black lead, if blower works replace switch. 94
Old Nov 18, 2014 | 09:41 AM
tamboo's Avatar
10 Year Member
ok switch and resistor replaced, motor works with a jump.
no voltage at the motor on the blue/white.
so it's either open wire/bad ground/bad relay right?
(or bad new parts).
it's 20f out there now so i'm not too motivated atm lol.
Old Jun 27, 2015 | 04:25 PM
tamboo's Avatar
10 Year Member
lmao summer temps here in the ozarks boonies finally provided the motivation necessary to revisit this issue. everything on the fsm flow chart tested ok but no dice. pulled the battery so i could get at the
lower part of the underhood fuse box just out of curiosity. cracked it open but it's still loaded with dielectric grease. put everything back together and a/c now works great!:w00t:!!!
so the question now is did the ecu reset while battery was out do the trick?:hmmm:
Old Jun 27, 2015 | 05:54 PM
wunfstgsr's Avatar
Loved
Community Favorite
That does usually reset the ecu so idk..
s13hero
Acura TL, RL & ZDX
Aug 13, 2011 03:03 PM
MEBHB91EF9
Sep 16, 2008 07:52 PM
geezel81
Mar 22, 2008 06:27 AM
jdadams12
Sep 11, 2007 08:51 AM
hotimportcrx
Oct 11, 2005 05:03 AM
