accord 2004 transmission help!
I have accord 2004 k20 with 5spead transmission, manual. I need 6 gear.
Does anyone know, can I put 6speed transmission from accord K24 2003?
Re: accord 2004 transmission help!
should be a direct bolt on as far as the transmission goes (So long as both engines are indeed K series). As far as I know all the K series engines have the same mount points for the transmissions.
You may have to modify the stock shifter mechanism for it to work with all 6 gears though. You could also simply use a 6 speed shifter mechanism in place of the stock one.
raffydogg
03-22-2008 08:53 PM
