2010 Accord Crosstour blinking D4 light speedometer and gear switch issue
Hi Everyone,
The Backstory
I left a bluetooth to radio gizmo in the cigarette lighter socket of my ~60,000 KM 2010 Accord Crosstour and that drained the car battery in a week while I was on vacation. When I came back, I replaced the battery and then the problem appeared.
The Problems
Kind Regards,
Peter
The Backstory
The Problems
- Check engine light on
- ABS light on
- D4 light blinking
- Speedometer going to zero intermittently / not working
- Cannot accelerate - RPM goes up but speed stuck at 10-20 kph, seems to be stuck in first gear?
- P0107 - Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
- P2138 - Accelerator Pedal Position Sensor A/B Incorrect Voltage Correlation
- P0452 - Evaporative Emission Control System Pressure Sensor Low Input
- P0651 - Sensor Reference Voltage 'B' Circuit Malfunction
- P0722 - Output Speed Sensor No Signal
- P2422 - Evaporative Emission System Vent Valve Stuck Closed
- C1555
Kind Regards,
Peter
Re: 2010 Accord Crosstour blinking D4 light speedometer and gear switch issue
Update: this may be a Engine Control Module issue, as if I unplug the power (battery) and reset the computer, the problem is fixed temporarily. The same issues comes back in a few days (couple of hundred KMs).
doitmyself2010
05-24-2010 12:58 PM
BlazeTeck2000
10-03-2004 09:58 PM
