2008 Accord Headlamp dimming issue
If you have the same problem as me-headlamps dim when a/c comes on please report this to the NHTSA
http://www-odi.nhtsa.dot.gov/ivoq/index.cfm
Also more info on this topic is at:
http://www.hondacarforum.com/h....html
Re: 2008 Accord Headlamp dimming issue (MSchu)
Okay, Simple answer though you didn't ask.
Your alternator is running off your pulley system (crank pulley). When your AC engages, the CLUTCH locks real quick (thus engaging) so the AC condensor can do its job.
What happened here?
When, for the SPLIT SECOND that the the AC clutch engages, it puts an EXTRA load on the crank pulley slowing it down. Which also slows the pulley revolution on the alternator.
Imagine you've got one hula hoop around you...you've got a nice rhythm going, easy.....then someone tells you to put a second one on without letting the first one drop....Well, In order to get the second Hula Hoop on, you have to slow down just a tad bit. But once they're going in unison, everything's back to "normal." Essentially same thing with your AC. Factor in the blower to the current being drawn too, and you've got yourself a pie.
What happened here?
You must be kidding-how can you say that headlamps that dim every 15 seconds is "normal"? None of Honda's other cars does this. None of the cars in my life has ever done this. Obviously the alternator or whatever can not handle the load-thus there is a problem.
Happens in my 03 AT I4 and has since it drove off the lot.
Have seen in it numerous other vehicles (not honda) including those with V6 engines as well as I4.
Though I will say the dimming only occurs momentarily during a new load demand and quickly recovers. Never have had a continuous 15 second issue.
Honda is working on a fix to this "Normal Characteristic". I was told it will involve an ECU and ECU wiring harness replacement. If it were "normal", I don't think they would go to this much trouble to "fix" it. I tried to start the Lemon Law clock on my 08 4 cylinder, but the Honda District Rep forced the dealer to close the Repair Order since there is "no fix available". Sounds like Honda is trying to cover this one up.
Timothy Yhtomit
12-04-2018 09:02 PM
redacura
05-26-2008 03:57 PM
Black R
11-15-2005 02:19 PM
