Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord window problem
Old 06-25-2015, 04:47 PM
  #51
Kevin1952's Avatar
Default Re: 2007 Accord window problem
Thank you to Claydorris, justinsbg, tkamal, and soo2bdropped. I will attempt the fix.
Old 10-20-2016, 06:28 PM
  #52
Autonetwork713's Avatar
Originally Posted by justinsbg
At the 23 pin white connector on the multiplex unit there is a white/green (white wire with a green stripe). The wire has a solid black wire and a solid blue wire beside of it. It's the only white/green wire in the connector so it should be easy to locate. With the ignition switch in the on position and the connector plugged up, with a jumper wire ground the white/green wire to body. Once that is done see if you can work the 3 windows up and down. Let me know what you find.
same problem here. Windows not working l just clicking. So I jumped #3"cavity and grounded the wire to the body. All windows started working fine. But the right rear passengers side won't go back up anymore. It clicks when I push the button down. Doest click when I pull up. Now I'm stuck with a window that's down. Any suggestions. And it's gonna rain tonight.
Old 10-22-2016, 06:54 AM
  #53
poorman212's Avatar
Humm, try applying power and ground directly to the window motor - if there is still nothing, replace the window motor ???
Old 10-23-2016, 11:42 AM
  #54
I opened the door panel to get to the motor. A tiny piece of plastic fell out from inside. I investigated it. Couldnt find a place for it and put it aside. Now I applied power directly to to rear passengers side window motor and It worked fine. I changed out the master switch which was the original problem to begin with. Now all windows are working fine except the passengers rear only goes down ( the clicking noise only when pushing down). My attention went back to that tiny piece of plastic with 4 prongs that had fallen off. After carefully examining the piece i found a fit. It belonged inside the switch between the citcuit board and the switch which would move and make a connection when pushing the switch up and down. I put that piece in place now everything works fine!
corkss
11-30-2008 06:46 PM
chickpat
01-21-2008 05:40 PM
GavinJuice
10-07-2006 08:07 AM
Lostmind004
11-22-2005 12:58 PM
manwezy951
04-02-2005 09:14 PM
Quick Reply: 2007 Accord window problem
