Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 accord turn signal and hazard lights not working please help me
Old 11-10-2014, 04:31 PM
Maxfever1987's Avatar
Default 2007 accord turn signal and hazard lights not working please help me
I have a 2007 accord 4 door, I had the issue of the flasher relay making the buzzing noise, so I went ahead and pulled it out and inspected the circuit board within the plastic housing,everything on the circuit board looked ok, but I plugged it back up without putting it back into it's plastic casing and I wound up inserting it incorrectly, and ever since I have no turn signals and no hazard lights,
I even put in a new flasher relay and it doesn't do anything,
So I'm thinking, did I short a wire? Ruin some kind of electrical component? Bcm maybe?
But the fuse within the engine bay is still good, even though I put the relay in the wring way it never blew the fuse,
Does anyone know where I should start? Or know what electrical component I should look into, I can't drive without turn signals for too long
Old 11-10-2014, 04:41 PM
Global Moderator
tech8's Avatar
Default Re: 2007 accord turn signal and hazard lights not working please help me
Check under-hood Fuse No. 16 (15A) and under-dash Fuse No. 21 (7.5A).
Old 11-10-2014, 04:49 PM
I did do so, both are fine, but still I replaced both with new ones, still same issue,
Old 11-10-2014, 04:55 PM
As a side note, everything else in the car works fine, just these 2 lighting systems don't, since the fuses are good, I believe it's safe to assume it's not a shot in the wiring?
Old 11-11-2014, 11:25 AM
VeeSykkz's Avatar
Bad signal relay.
Old 11-11-2014, 01:23 PM
Originally Posted by VeeSykkz
Bad signal relay.
There's a brand new one in there,
Old 11-11-2014, 05:15 PM
Is there any diff. In getting one from Honda or is te autozone one good enough? It is exactly the same and also says omron on it as well, along with the same voltage specs
Old 11-12-2014, 04:14 AM
Anybody have access to the electrical wiring diagram for the 07 accord?
Old 11-12-2014, 07:26 AM
So I have found the factory service manual online I will post up the link so every one here can use it, and it's strange but the circuit that's controls the turn signals and hazards is actually located within the wiper switch
Old 11-19-2014, 02:45 PM
Update i have solved the problem, it was the micu, i changed it out for another one and everything works as it should, pretty to install as well,
kap10Hook
03-19-2012 10:39 AM
JDM Projects
07-26-2011 06:18 PM
1992acurainteg
07-27-2007 07:40 PM
premo_si
08-05-2006 10:07 AM
egriggs85
03-02-2006 02:49 PM
Quick Reply: 2007 accord turn signal and hazard lights not working please help me
