Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2005 Accord EX-L V6 Engine Light
Old 11-19-2014, 12:15 PM
Chuck_T's Avatar
Default 2005 Accord EX-L V6 Engine Light
The maintenence required light and engine light are both on. I know that my oxygen sensor needs replacing, but will that also take care of the maintanence required light?
Old 11-19-2014, 12:59 PM
BLKFLSH's Avatar
Default Re: 2005 Accord EX-L V6 Engine Light
The information on how to turn the maintenance required light off, is in the owner's manual.
Hold the trip/odometer reset button, with your left hand. Keep holding the button down, and turn the key to position II (on, not start). Continue to hold the button until the light goes out (10 seconds). Don't just turn the light off, do the maintenance that is due. If you don't have an owner's manual, you can get all the information from the Honda owner's link. Just about any auto parts store can read the codes for the check engine light.
Old 11-19-2014, 01:08 PM
Chuck_T's Avatar
I tried to get the light to go out following the steps, but it comes right back on. I already found out I need a oxygen sensor. Are they hard to replace? Can I do it myself, or should I get a mechanic to do it...
Old 11-19-2014, 04:41 PM
BLKFLSH's Avatar
If you can't get the maintenance required light off, I would bring the O2 sensor to a professional.
Old 11-21-2014, 10:30 PM
Lucky Flow's Avatar
If it's the lower 02 sensor under the car, then it's easy.
You're only trouble is to get under the car using a lift, don't use jacks.
You can rent the tool for free at Autozone or Advance Auto with a deposit.
And for the love of God, do remove the seat to get to the plug thing.
Also, use a flat head screwdriver to remove the black plastic tabs, from the front.
dilltheswimr
04-24-2007 06:22 PM
edger8cer
07-21-2005 06:03 AM
billybong91DA
11-26-2003 11:32 AM
CrAzyGsR101
Acura TL, RL & ZDX
10-17-2003 06:09 PM
Jetstream
12-13-2001 08:20 PM
Quick Reply: 2005 Accord EX-L V6 Engine Light
