2004 Accord Wheel Question
I have 2004 Accord with stock wheels 205/65/R15, I am planning to get a set of winter tires and rims. A guy is selling me his set from his Mustang, same 205/65/R15 tires plus the rims with 5 x 114.3mm bolt pattern as I have searched in the net. I checked also that Accord uses the same 5 x 114.3mm lug pattern but it is listed as 15 x 6 while the Mustang is 15 x 7. Can I still use it for my car. Thanks and more power.
Re: 2004 Accord Wheel Question (fratinggutom)
u also have to look at teh offset of the rims, they might be differenti know hondas run between 40-45 , im not sure about mustangs but they might be lower , but im not also sure the offset makes a different but if it does i would check if they fit and wont rub on ur brake caliper,,,,,
In a Junkyard near you.
You might get some vibrations from them. Mustang wheels are lug centric and Honda wheels are Hub centric. Also expect your car to become unreliable, cheaply made and mundane.
Re: (Ross 2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 »</TD></TR><TR><TD CLASS="quote">You might get some vibrations from them. Mustang wheels are lug centric and Honda wheels are Hub centric. Also expect your car to become unreliable, cheaply made and mundane.</TD></TR></TABLE>
Haha. Yeah, I would expect vibrations but not the other things Ross stated
( o )( o )
12
12-21-2007 09:25 PM
markm859
07-05-2005 08:19 AM
