09 Accord 3.5 Manual Swap Help (ivtec vcm and VTEC )
Hey guys so I bought a 2009 3.5 litre v6 , 6 speed manual transmission accord with engine knock, so I ordered a 2009 3.5 v6 engine from automatic transmission (only reason is because i searched carpart and no one had a 6 speed engine in canada), I swapped the flywheel over , and I see that the automatic has different intake manifold o i am going to swap that over a well as mine has a dual plenum manifold,
I know I'll be using my original harness from my old motor to accommodate the manual transmission sensors . i also see that the VCM heads have a few more sensors on them where as my heads dont, i called honda and they this say the engine block is the same, so my theory is if i swap my heads over from my 6 speed engine , as well as the intake manifold and harness it should be good to go?
any help would be appreciated guys, thanks
also head bolts, can i reuse them or do i need new ones? i did plenty engine swaps but never took apart heads. thanks
and torque specs?
and torque specs?
trinikron
08-11-2010 05:14 PM
