Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
'08 Accord Coupe Fuel Sending Unit Replacement
Old 02-17-2013, 07:19 AM
Matt169's Avatar
Default '08 Accord Coupe Fuel Sending Unit Replacement
Fuel gauge has been stuck on empty with low fuel light blinking. Fuses checked OK. Did the dash check process and fuel gauge worked during that test. I have now ordered a replacement fuel sending unit and am ready to install.
Looking for help with how to access the fuel sending unit for replacement on my 2 door Accord. Access from the trunk or under the back seat? Thanks!
Old 02-17-2013, 07:34 AM
JDM95Honda's Avatar
Default Re: '08 Accord Coupe Fuel Sending Unit Replacement
it is more than likely in the trunk you have to pull up the carpet and what not ane worst case scenario just drop the tank
Old 02-18-2013, 11:56 PM
KWayRacing's Avatar
That would be a worst case scenario. It is a task to just drop the tank. The pump access cover is under the rear seat like a 92-95 civic. You'll most likely find a varmit has had dinner on a wire once you gain access. If it is actually a sending unit I will be surprised.
Sordz
02-18-2010 12:20 PM
Jack42038
12-28-2008 08:32 PM
focker1636
05-24-2004 04:53 AM
wannakno
06-27-2003 08:20 AM
Quick Reply: '08 Accord Coupe Fuel Sending Unit Replacement
