Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
07 crv motor into a 07 accord
Old 08-17-2010, 04:30 AM
justa4dr's Avatar
Default 07 crv motor into a 07 accord
hey everyone ive got a bit of a predicament here i have a motor out of a 07crv that i need to put in my 07 accord i know there is some differences like where the oil filer location and drive shafts, if anyone has any info on this swap let me know
Old 08-17-2010, 08:12 AM
xpehbam's Avatar
Default Re: 07 crv motor into a 07 accord
It does not sound like a good idea to me, any car with a motor swap is a big headache in the future
Old 08-17-2010, 10:58 AM
Seagull Management
94EG8's Avatar
Using a blanket statement like that is just ignorant. There are lots of engine swaps that a dead reliable and use nothing but OEM components right down to the engine mounts and wiring.
In this case the OP wants to swap a K24 variant with a different K24 variant. Should not be overly difficult.
Old 08-20-2010, 11:18 AM
Alfspeed's Avatar
what the crv engine code? the accord is k24a8, I guess the 07 CRV its k24z1, the swap should be simple, but not plug and play :D
Old 08-20-2010, 01:41 PM
Superfly
Samuraij's Avatar
Is there really that much of a difference between the K24a8 and the k24z1 that it wouldn't be that easy?
Old 08-20-2010, 01:45 PM
Dokta's Avatar
If by plug and play you mean a device which facilitates the discovery of hardware in a system, without the need for physical configuration; then no, it is not plug and play.
Both these engines are pretty much the same. I don't see any problems at all with this swap.
The only differences are in the engine components. The size and configuration of the cylinder head, and the block are identical. Don't expect to be able to install the engine without first inspecting the intake and exhaust manifold, alternator, ac compressor, and sensors. Some of these components may need to be swapped out for the ones on the accord engine.
Any competent Honda technician should be able to complete this swap in a few days. But like I said, you cannot assume anything here. Everything must be inspected and compared before installation.
Old 08-23-2010, 02:36 PM
cate)'s Avatar
not to be a party pooper but the swap is going to take some work. Blocks are way diffrent like oil filter where half shaft should be and sutch. Also the intake manifold lies a diffrent configuration bc it is mostly plastic and uses a totaly diffrent setup for coolant passages and egr flow. Good luck keep us posted on the build>
v4lu3s
03-28-2012 06:20 PM
accordcvcc78
Classic Hondas
05-16-2010 10:25 PM
japle
03-16-2006 10:01 PM
steph_accord
03-31-2004 05:44 PM
Quick Reply: 07 crv motor into a 07 accord
