Winshield Squirter problem!!! Help!!!
Old 02-12-2002, 12:26 PM
scrubachu's Avatar
Default Winshield Squirter problem!!! Help!!!
my windshilked squirteers stopped working out of nowwhere. i have not a clue why. i checked the fuse for the wipers, its ok, everything works except the squirters. any ideas??
Old 02-12-2002, 12:40 PM
Accord94DX's Avatar
Default Re: Winshield Squirter problem!!! Help!!! (scrubachu)
You live in florida so im guessing there is no ice in the line.....um, maybe it was just the washer pumps time dude...let it go...
Old 02-12-2002, 12:51 PM
SOHCArchangel's Avatar
Default Re: Winshield Squirter problem!!! Help!!! (Accord94DX)
check the nozzles see if they are clogged, use a sewing needle to probe..
Old 02-12-2002, 01:43 PM
dvsOasis's Avatar
do the windshield wipers sweep across the window? Do you hear the pump working? Are you sure you have windshield wiper fluid left?
Old 02-12-2002, 02:22 PM
V6CpeGirlie's Avatar
I had the same problem. I just needed to add more winshield wiper fluid (doh!). Hehe, that, and the nozzles were clogged.
Old 02-12-2002, 02:34 PM
New User
Gennady's Avatar
Default Re: Winshield Squirter problem!!! Help!!! (V6CpeGirlie)
Your line might be twisted or bent and not allowing any fluid through. Or, add more fluid.
Old 02-12-2002, 03:51 PM
scrubachu's Avatar
Default Re: Winshield Squirter problem!!! Help!!! (Wont be beat)
lines arent twisted, nozzles arent clogged. i replaced everything before it went dead. i dont hear the motor. thats my concern. i should check the washer fluid. hehe. ill do that tom. but i still dont hear the motor, so i may crawl under there and check the connection to the motor at the bottom of the washer tank.
Old 02-12-2002, 04:17 PM
Kazmans94cord's Avatar
you know what time it is....time to get some of them blue led nozzles!!! totally joking!!!!
Old 02-12-2002, 07:04 PM
CmptchAV6's Avatar
Default Re: Winshield Squirter problem!!! Help!!! (kazmans94cord)
I had the problem with the clogged nozzles on my civic after I washed the car and waxed it some of the waz stuck in there so I took a toothpick and cleared it out. another cool thing that I never knew until mine clogged was that the little sprayers in their can actually be adjusted angle and everything so I went and got them perfect where they sprayed the areas for the best cleaning of the windshield
Old 02-12-2002, 08:24 PM
New User
Gennady's Avatar
Wanna buy mine?
Raguillon
11-12-2013 02:06 PM
Importn2oRacer
01-22-2010 11:43 PM
HanSnobbler
07-22-2005 08:14 PM
enthusiast128
01-29-2002 01:16 AM
Quick Reply: Winshield Squirter problem!!! Help!!!
