window switch
Old Jan 8, 2009 | 10:21 AM
killadipset06's Avatar
Default window switch
so i replaced the motor in my window on the driver side but the guy that put it in said it will go down but wont come back up....he said the switch is bad in the door that allows this.....anyone know where i can get one from????????PLZ HELP CAUSE MY INSEPECTION IS PASS DUE!!!! AND THA JUNKYARDS DONT HAVE IT
Old Jan 8, 2009 | 10:24 AM
P_Adams's Avatar
Default Re: window switch
Try these guys:
http://www.tasauto.com/Product/Browse.aspx?d=103&p=1
P
Old Jan 8, 2009 | 12:43 PM
Brad_and_the_acc's Avatar
I usually clean mine.
To take out the master switch( driver side switch ) there is a screw in the arm rest of the door in the switch pocket. Once the screw is out lift up and pull towards the front of the car. Unplug the the wires from the rear view mirror controls and the window/`s switchs. You can unscrew the switch from the door trim/ door pocket with a small size phillips driver. There is a rubber like guard thats is around the switchs, peel it back but dont rip it. Push on the pin that holds the toggle to the contacts for the relay. The toggle will be able to just lift up now. There is going to be 2 contacts in there, one for up and one for down. You should visually be able to see grime, grit, dust, coke, boogers, whatever the case may be in there. Clean with a quetip and re-asemble.
Sounds like quite a bit, but it is realy easy and has worked EVERY time for me if its the relay thats bad. The window switch/ relay is simple mechanics and just realy need a clean connection for them to work right. But I have heard of some that actually do go bad. But I have never come across one that couldnt be fixed. It is deffinitly worth a shot though. You cant go wrong, atleast try this or......... spend 50 upwards to a BILL on a new one. Thats up to you.
jds113
Aug 7, 2010 05:04 PM
hondapwr
Jul 17, 2009 05:30 PM
v-tecnition
Oct 6, 2008 01:19 PM
FOSHO
Dec 18, 2005 06:21 AM
spd18
Jun 15, 2003 10:32 PM
