window problems
aight i need some help. my drivers side front window will not work. i have tested the window motor and the switch, the motor was ok and the switch was bad so i got a new switch and it still will not work. has this happen to anyone or does anyone know how i can fix it?
i dont know much about this, and i dont mean to sound like an *** especially it being your first post, but use the search button. it is there for this very reason. in the search field type window ... then select accord from the drop down menu, and then choose archived content ... then press search. i found 78 results, and im sure your answer lies within. good luck, and if you cant find anything there come back and re-post! and welcome to H-T!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandonwiley »</TD></TR><TR><TD CLASS="quote">aight i need some help. my drivers side front window will not work. i have tested the window motor and the switch, the motor was ok and the switch was bad so i got a new switch and it still will not work. has this happen to anyone or does anyone know how i can fix it? </TD></TR></TABLE>
What you need to do is describe it a bit better.
1. Do you hear the motor trying to raise the window?
2. How do you know the motor is good?
fs
fs
i know the motor works cause i jumped power str8 to the motor and it would roll up and down
its like it just loses power between the switch and the motor somewhere. the new switch works fine in my girlfriends accord. so i know its not the motor or the switch
i really dont understand it. i work at a body shop and its got us all stumped. 1 guy said that he thought he remembered the same thing happen 2 some1 else and he said he thought that they replaced the power lock control module inside the door and its worked fine ever since
meshuga
Dec 1, 2004 12:03 PM
