Window Problems???
Old Oct 14, 2008 | 04:42 PM
killadipset06's Avatar
Default Window Problems???
ok so i got my window regualtor on my driver side replaced and it will go down but will not go back up....what is tha problem?
Old Oct 17, 2008 | 01:36 PM
P_Adams's Avatar
Default Re: Window Problems??? (killadipset06)
Honda techs and Dealers replace what is known as the guides and channel runs for this condition.
In effect, what happens over time is that these guides get contaminated with all sorts of road grime and such which slows how the glass runs up and down in the guide. When the glass tilts (I was about to use a non-PG word there) it binds in the guides and there you have it - Water damage :-(
Old Oct 25, 2008 | 09:08 AM
Default Re: Window Problems??? (P_Adams)
so what would i have to do fix this problem?
Old Oct 25, 2008 | 09:45 AM
Klimx03's Avatar
I just got a new motor for my window and it fixed my problem
Old Oct 25, 2008 | 12:12 PM
P_Adams's Avatar
If you can spot the window tilting as it trys to go up, and grabbing the low end and pulling helps it close: then you've got a bunch 'o crud which is binding the glass in the guide by making it not slide evenly (just as I mentioned earlier).
As a temporary fix (and I do mean TEMPORARY) try loading up the window runs with spray silicone lubricant. If it starts working better, then my prognosis is confirmed.
A permanant fix is to replace the guides and the run
P
Old Oct 26, 2008 | 08:08 AM
erk89's Avatar
Default Re: Window Problems??? (Klimx03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klimx03 &raquo;</TD></TR><TR><TD CLASS="quote">I just got a new motor for my window and it fixed my problem</TD></TR></TABLE>
The regulators aren't always the problem, I've replaced my drivers side 3x now and am waiting for the run channels. I WOULD NOT suggest sylicone lube or any other kind of lube because from personal experience all it does is collect more dirt and grime and make it worse.
Old Oct 26, 2008 | 01:41 PM
P_Adams's Avatar
Default Re: Window Problems??? (erk89)
That is why I was VERY careful to say TEMPORARY (as in non-permanant), and as a diagnostic tool ONLY.
P
dingobat
Oct 9, 2008 09:56 AM
ricist
Honda Civic (2006 - 2015)
Apr 16, 2008 05:37 PM
HondaMike17
Dec 2, 2005 04:49 AM
rasinhell
May 20, 2005 12:38 AM
acme
Nov 4, 2002 06:39 AM
