Honda ACCORD NOT START.. NEED HELP
Old 12-21-2014, 03:00 PM
Howard38's Avatar
Icon2 Honda ACCORD NOT START.. NEED HELP
93 Honda accord 4cyl 2.2 liter. Was driving my Honda on road stopped at stop light. went to give gas engine was not running tried to start car would not start. it will turn over but will not start. check plugs gap ok on plugs. wire seem good. fuel pump is working filter is good battery is ok. Replaced coil pack car still will not start but turns over. I NEED HELP DON'T KNOW WHATS NEXT.
Old 12-21-2014, 03:01 PM
Howard38's Avatar
Default Re: Honda
Old 12-21-2014, 03:05 PM
toker2's Avatar
Default Re: Honda ACCORD NOT START.. NEED HELP
Timing belt? Open your oil cap, look down in the hole with a flashlight and verify the rocker arms are moving up and down while an assistant turns the key to Start.
Old 12-21-2014, 05:54 PM
nus_dogg's Avatar
^^ That. To verify that the timing belt is still on.
Old 12-23-2014, 11:21 AM
tim73's Avatar
If timing is ok, check crank position sensor.
Old 12-23-2014, 12:50 PM
holmesnmanny's Avatar
Check for spark.
Old 01-01-2015, 09:46 PM
Howard38's Avatar
Icon2 Re: Honda ACCORD NOT START.. NEED HELP
thank u for ur input & yes was a timing belt.. i replace timing car ran find for 30 mins but once she got warm sitting at stop light she starts to act up she wants to die i put her in neutral she acts a little better..i step on gas she spits until she hits at 15 or 20 MPH then she runs fine. timing is set right rpm set at 600. i checked vacuum system by spraying carburetor fluid on every line no change in idle speed. ANY one now what to do?????
Old 01-02-2015, 12:24 AM
Compression test for possible damage.
Old 01-02-2015, 03:46 AM
94 accord typeR's Avatar
Main relay if it works u gotta buy me a beer
Old 01-02-2015, 04:05 AM
tim73's Avatar
If the timing belt broke, compression test needs to be done. Might have a valve slightly belt...leaking a little bit.
SentinelK151
08-06-2017 08:42 AM
Tulga
02-22-2016 07:47 PM
shaney3181
07-17-2009 09:40 AM
Quick Reply: Honda ACCORD NOT START.. NEED HELP
