01 ex barely idles after clutch install
Old 06-19-2011, 07:22 AM
WhiteOnRice's Avatar
Default 01 ex barely idles after clutch install
2001 ex accord
2.3L
148k miles
no engine problems before install
Hey guys I installed a new exedy oem clutch in my Dad's Accord (motor and trans up and out). Everything went pretty smooth, I had to unclip all sensors because the harness didn't disconnect at the firewall like my Civic. I broke the knock sensor unhooking it and had to replace. Anyways, first turn of the key it started right up and I let it idle about 5 minutes while I filled the coolant.
When I tried backing it out of the garage and giving it a little gas, it died. Started right back up again and died 1 more time but I got it out. There is no CEL, the car just doesn't seem like it knows WTF to when there is any type of change in its power needs -- give it gas, turn the wheel fast, turn a/c on, etc. It'll either die or almost die and it idles too low.
This was about a week ago and it *seems* like the car runs better every day I wait. Eventually I could rev it to about 4k (with major pulsing) and got it into second gear while driving but at the rate it's going, it seems like it'll take 2-3 weeks to drive normal--it FREQUENTLY dies while driving. I've done swaps where the car needed to relearn its idle and all but this is much more dramatic. Maybe because all sensors were unplugged? Anyone have a diagram of the IACV on this gen accord?
I have 2 videos I uploaded to youtube that are waited to be approved to better explain.
Old 06-19-2011, 07:45 AM
Default Re: 01 ex barely idles after clutch install
First vid: http://www.youtube.com/watch?v=7XpKinv3hEo
Old 06-19-2011, 01:48 PM
Chiovnidca's Avatar
Did you have the tps and map sensors disconnected? If yes try switching the connectors.
Old 06-21-2011, 06:14 PM
That was it! Thanks Chio!
And thanks Honda for making 2 sensor clips the same within such a short distance. :p
Old 08-01-2011, 07:20 PM
Chiovnidca's Avatar
Yea i've done it myself more than once, and seen plenty of other techs do it too. They do color code them, i just cant ever remember which is which. LOL
WhiteOnRice
06-21-2011 06:15 PM
msand9898
02-03-2009 10:52 AM
henrynj1
02-24-2007 08:34 PM
Quick Reply: 01 ex barely idles after clutch install
