Newby with two tech issues...
Old Feb 2, 2009 | 10:39 PM
msand9898's Avatar
Default Newby with two tech issues...
Ok, this all started when my clutch went out...Everything else was working fine at this point except clutch.
So I had a mechanic friend change out my clutch on my 93 accord ex.
Removal went fine, install went as expected...
So he showed me that it now started and went into every gear without any issues and showed me that my clutch engaged and disengaged properly...
So I paid him and he was on his way and my family hopped in the accord to go out for ride.
Well i started it up and I put it in reverse and backed up but when I got to the end of the driveway I noticed that I had no power steering?
So I figured I would drive and at a few stop lights I would turn the wheels left & right to bleed the system.
This proved wrong? I still don't have power steering and it worked flawlessly prior to the clutch going in.
I even tried bleeding the system at home...and all belts are on th right way and are a week old.
Mechanic friend is out of town for a week and I need my car back , so anyone have any ideas on what may be the issue. i
Also one more question, Anyone know what gets connected to this fitting above the transmission where the shift cables connect there is what appears to be a long tubing connector, what goes connected to it, because nothing is connected to it? because it is really clean like something covered it before?
Old Feb 3, 2009 | 07:33 AM
msand9898's Avatar
Default Re: Newby with two tech issues...
anyone ?
Old Feb 3, 2009 | 09:27 AM
P_Adams's Avatar
Vent hose (I believe) goes there. It's the highest point on the transmission case which never sees circulating lubricant. Refer:
http://www.hondaautomotiveparts.com/...RM-SHIFT+LEVER
http://www.hondaautomotiveparts.com/...ISSION+HOUSING
Old Feb 3, 2009 | 09:37 AM
msand9898's Avatar
Thanks a bunch, I figured it was an important part, if its not caped off will it make the steering feel like a pulling on dead weight?
Old Feb 3, 2009 | 10:52 AM
P_Adams's Avatar
No, That should have no bearing on Power Steering performance. There is a Variable Effort Valve incorporated in the VSS housing on most Accords which could cause that condition, but this is not that. Refer:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=ACCORD&catcgr y2=1993&catcgry3=4DR+EX&catcgry4=KA5MT&catcgry5=P. S.+HOSES-PIPES
Hoses #27 and #10 attach to it. (located in the wnw quadrant of the illustration)
P
mrrugsr
Oct 26, 2013 10:36 PM
fwdtamiya
11
Feb 5, 2006 12:06 PM
SloCivicHMM
Sep 13, 2005 05:29 AM
nostalgia
Apr 25, 2003 09:11 PM
mikecel79
Apr 10, 2002 01:41 PM
