where is my 02 accord ecu located
Re: where is my 02 accord ecu located
It located in the center console below the radio.
See this TSB for an illustration.
http://www.tegger.com/hondafaq/tsb/accord/x97-058e.pdf
well thank you i appreciate the help, now my other question is which wire would be the signal wire for the primary 02 sensor on a f23a4 engine, in the diagram it shows c16 on this site http://www.innovatemotorsports.com/r...nda_Accord.php, but i don't have a wire there and my engine is the ulev vtec, also this site gives me something different http://krcomp.com/pictures/ecu-pinout.pdf,
how come it still shows that there is a c16 pin and on my ecu there is none? also i connected my air fuel ratio guage and nothin happens it just reads rich could this be because of a bad 02 sensor or no cat?
The reason the service manual shows a C16 pin is because the service manual covers different engines for those Accord years. C16 is for the F23A1 or F23A5 engine, which has a normal heated oxygen sensor. Your's doesn't have that pin because your's a F23A4, which has a air/fuel ratio sensor.
92prelude23
11-29-2008 01:08 PM
camp_kill_yourself
01-05-2007 11:44 AM
