what code is this i thick it is code 5
Old Oct 30, 2009 | 06:16 AM
1993-eg1's Avatar
Default what code is this i thick it is code 5
so i have been finishing up with the first part of my project and i am geting a code i thick that it is code 5 map
http://s304.photobucket.com/albums/n...91029-1752.flv
Old Oct 30, 2009 | 06:27 AM
redbull-1's Avatar
Default Re: what code is this i thick it is code 5
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/RDvTxu_Z1FY&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/RDvTxu_Z1FY&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Looks like HTML code. Just kidding.
Looks like Code 41 (Four long, one short) - Primary oxygen sensor heater
Old Oct 31, 2009 | 02:24 PM
1993-eg1's Avatar
would some one have an idear? I have wired in a new o2 and new wiring to the ecu and still have the same code.
Old Oct 31, 2009 | 02:25 PM
1993-eg1's Avatar
I am using an 94 accord ls ecu I believe it is a p0b
Old Oct 31, 2009 | 02:44 PM
mavvrik's Avatar
Well than it might be a 41, but that's what it looked like to me too.
Double check it and see if you get the same flash pattern.
It's possible you could be running rich/lean causing your 02 sensor to read wacky. It could also be giving that code if you have messed with your exhaust aka running with no cat
Old Oct 31, 2009 | 03:03 PM
1993-eg1's Avatar
this is how i wired it in
D14 - ORG/BLU at O2 plug (engine harness side) - WHT (4 wire O2 plug)
D22 - GRN/WHT at O2 plug (engine harness side) - GRN (4 wire O2 plug)
A6 - YEL/BLK at O2 plug (engine harness side) - BLK (4 wire O2 plug) There are 2 BLK wires and either one can make either connection. The second BLK wire is connected to B1
Old Oct 31, 2009 | 03:05 PM
1993-eg1's Avatar
? have i some how gotten an ecu uses 2 o2s I thought that the p0b was an obd1 ecu and used just the 1 o2 at the header
Old Oct 31, 2009 | 03:41 PM
Targa250R's Avatar
be professional
Definitely a code 41.
There are both OBD-1 and OBD-2 versions of the P0B ECU. What is the exact part number printed on your ECU? The last three numbers are important. 37820-P0B-xxx??
Also, what sort of oxygen sensor did you buy? Part number?
Old Oct 31, 2009 | 06:46 PM
GhostAccord's Avatar
Sensor GRN -> GRN/BLU -> D22 ECU (SG2)
Sensor WHT -> WHT/RED -> D14 ECU (O2S)
Sensor BLK -> ORG/BLK -> A11 ECU (HO2S HTC)
Sensor BLK -> YEL/BLK -> (Junction Box) A25 ECU
Old Nov 1, 2009 | 05:47 AM
1993-eg1's Avatar
if u look at this pin out u see that a11 is a egr pin do i still use it or was this typo
Old Nov 1, 2009 | 05:54 AM
1993-eg1's Avatar
is the pob fussy about this type of stuff and shoud I just get a chiped p75 or some other non-vtec ecu
Old Nov 1, 2009 | 06:16 AM
I'm pretty sure that pin out is for an OBD1 P06/P28 Civic/Integra. It states under A11, that it is EGR for the Civic SOHC and H22/H23.
Here is the Honda shop manual for the OBD1 94-95 Accord ECU diagram. It could be wrong but I haven't had any code problems with any of my wiring as of yet.
If you get a chipped ECU it will be more of a pain than fixing this problem. It is not the P0B ECU that is any more fussy than the other ECUs. It requires certain signals to be sent to the ECU from sensors on the engine. If those signals or voltages are out of spec. The ECU will throw a Diagnostic trouble Code (DTC/CEL/MIL) this is the same for every ECU not just the P0B.
Old Nov 4, 2009 | 06:07 AM
1993-eg1's Avatar
would u have the wiring for the 2end o2 as well
Old Nov 4, 2009 | 06:35 AM
AFAIK there is no allowance for a SHO2S on the OBD1 P0A/P0B ECUs. they only use 1 O2 sensor. The OBD2 ECUs have both the PHO2S & SHO2S.
Did you want the diagram for teh OBD2 ECU? I have them as well.
Old Nov 4, 2009 | 03:13 PM
1993-eg1's Avatar
no, no need of them then just was told be a shop that i had one today ty
Old Nov 17, 2009 | 07:01 PM
1993-eg1's Avatar
well the o2 heat code. I gorn and i have been putting some miles on my car. and i am geting an egr code would some one know the pin out for the egr system so i can wire that up right
Old Nov 17, 2009 | 07:35 PM
The one labeled ESOL on the image above is your EGR solenoid. Located on the right side of the engine compartment.
RED -> A6
YEL/BLK -> 12v power source 7.5amp
EGR valve lift sensor, located on the intake manifold.
YEL/BLU -> D20 (Power)
GRN/WHT (GRN/BLU) -> D22 (Ground)
WHT/BLK -> D12 EGRL
drewboy
May 14, 2005 10:03 PM
93b18civic
Mar 21, 2004 06:48 PM
whagkangmakulet
Nov 25, 2002 12:27 PM
