weird stuff..!
Old Nov 2, 2004 | 11:17 AM
Juccord's Avatar
Default weird stuff..!
Sometimes when im driving along, just normal driving, suddenly my rev's start going up and down, not drastically, maybe up 300-400rpm then down 300-400rpm so then I would pull over and put it in neutral and they start jumping up and down, I mean like going from 800- 4000rpm, just up and down until I turn off my car, then sometimes even when I start it back up, it keeps doing it..! I brought it home to Honda, and they told me everthing was fine, I dont think so, if anyone has any Ideas please let me know, I think it might be my tranny (auto)..
Old Nov 2, 2004 | 12:35 PM
Shinbo's Avatar
Default Re: weird stuff..! (Juccord)
exorcism
Old Nov 2, 2004 | 01:12 PM
Juccord's Avatar
Default Re: weird stuff..! (Shinbo)
yah ive already checked that....
does antone else have ANY ideads??
Old Nov 2, 2004 | 03:34 PM
Trumpster's Avatar
My first thought would be the PCV valve. I know that when I disconnected mine to seafoam the car I got some variation in the idle. I am by no means an expert though, just figured I would throw in my 2 cents. Maybe timing, try checking that. I'm looking into trying to figure out how to check my timing right now so I can't tell you how. Sorry. GL
Old Nov 2, 2004 | 04:13 PM
TOAB's Avatar
tps, or vacuum leak probably.
Old Nov 3, 2004 | 06:50 AM
Juccord's Avatar
Default Re: (TOAB)
thanks for all the tips guys, I'll check the PCV valve, but I dont really know how to vacuum test it, or tps?? I dont even know what that is..!
And can anyone let me know what this seafoam stuff is, I keep hearing about it lately, and I have no clue what it is..
Old Nov 3, 2004 | 09:04 AM
momstaxi's Avatar
if the tachometer is jumping up and down rapidly, but the engine insn't revving up and down with the tach it would be an electrical problem. your problem would be a faulty ignition control module or an ignition coil.
Old Nov 3, 2004 | 11:45 AM
Juccord's Avatar
Default Re: weird stuff..! (momstaxi)
no, no, its the engine and the tach, how do you get it vacuum tested?
And whats seafoam?
Old Nov 3, 2004 | 04:07 PM
Sublime95's Avatar
Check the MAP sensor also. If you aren't sure where it is at then buy a Chilton's guide from Auto Zone. Mine does this also after I accelerate and then brake. Mine isn't the sensor but I was told it was a common problem.
Old Nov 3, 2004 | 05:03 PM
cyb3rjak's Avatar
seafoam is something people use to clean the carbon buildup inside the engine, pull out the vac line and pour some in with it running
Old Nov 7, 2004 | 10:20 AM
Juccord's Avatar
Default Re: weird stuff..! (cyb3rjak)
cool, im gonna check all that stuff, I'll let you guys know what I can figure out, thanks for all the help..
yo bj
Feb 2, 2011 05:54 PM
93 del slo
May 9, 2009 06:54 AM
ILuvMyJdmDc4
Nov 16, 2007 06:17 AM
94ludesi
Sep 27, 2001 07:11 PM
