Warning Light Question
Old Aug 24, 2005 | 07:20 PM
JP22379's Avatar
Default Warning Light Question
I have a 1991 Accord LX. What does the green blinking "S" on the dashboard mean?
_John
Old Aug 25, 2005 | 05:22 AM
SearchBeforeUPost!'s Avatar
Default Re: Warning Light Question (JP22379)
on your year/model, means you probably need to replace your tcm. try searching for this, it is a common problem amoung 4 gen accords.
Old Aug 25, 2005 | 05:30 AM
deserthonda's Avatar
u need to chk the code, then diagnose it before u start replacing parts and pissing money away ...
Old Aug 25, 2005 | 05:33 AM
JimBlake's Avatar
Default Re: Warning Light Question (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">u need to chk the code, then diagnose it before u start replacing parts and pissing money away ...</TD></TR></TABLE>Yeah, unless you have enough money to just put new trannys in without knowing if it's really bad.
Depending on what year, the tranny controller either uses the "S" lamp or the "D" lamp the same way as the check-engine light. You can read the code pretty much the same way as you read CEL codes.
Old Aug 31, 2005 | 10:04 AM
vedha's Avatar
Default Re: Warning Light Question "S" lamp
need help
accord ex 1990 "S" lamp was flashing a month ago.
but it comes when I start the car and stays on for about half a mile and goes off. can anyone give a clue.
Old Aug 31, 2005 | 02:11 PM
Chiovnidca's Avatar
Default Re: Warning Light Question "S" lamp (vedha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vedha &raquo;</TD></TR><TR><TD CLASS="quote">need help
but it comes when I start the car and stays on for about half a mile and goes off. can anyone give a clue.</TD></TR></TABLE>
Does it have a trouble code stored?
Argenis 2524
Feb 5, 2016 11:48 PM
triniberg
Oct 25, 2012 05:45 PM
aznpreludeSH
Mar 18, 2008 11:30 AM
coolrahool
Oct 27, 2005 04:34 PM
