Vtec start point
Old Nov 19, 2002 | 07:52 AM
AccordCF4's Avatar
Default Vtec start point
Guys,
I got a V-AFC to play around with, and any good suggestion of where should I set my Vtec start point?
I did tried to set it at 5000rpm, but don't feel the power much.
BTW my F20B orginal start point is around 5500 rpm.
Old Nov 19, 2002 | 08:06 AM
Nick M's Avatar
Default Re: Vtec start point (AccordCF4)
Get on a dyno
Old Nov 19, 2002 | 08:09 AM
urbanlegend21's Avatar
New User
Default Re: Vtec start point (Nick M)
Get on a dyno
exactly, you are wasting your time without dyno tuning any type of VAFC
AccordCF4's Avatar
Actually I did, but I don't feel the power if I set it to 5000rpm.
Old Nov 19, 2002 | 08:10 AM
AccordCF4's Avatar
I mean, those people let me choose the vtec start point and they just fix up the A/F ratio for me and that's it!
Old Nov 19, 2002 | 08:11 AM
New User
you used a dyno? did you tune the VAFC while on the dyno?
are you using a VAFC on a completely stock motor?
Old Nov 19, 2002 | 08:15 AM
CD8's Avatar
CD8
Default Re: Vtec start point (urbanlegend21)
L => H is set at 4700
H=> L is set at 4600
Old Nov 19, 2002 | 08:17 AM
AccordCF4's Avatar
Well they just did that for me.
I got a HKS power flow, exhaust from cat back etc.
Old Nov 19, 2002 | 08:21 AM
Stew Pidasso's Avatar
I have had good results with it set at 3500 but this is on a F22B
Old Nov 19, 2002 | 12:13 PM
Razor's Avatar
Default Re: Vtec start point (Stew Pidasso)
accordcf4, where are you from? you're lucky you got the SiR-T, thats one of my favs...
Old Nov 19, 2002 | 12:17 PM
SOHCArchangel's Avatar
this ONLY works on a f22 not any dohc vtec motor
Old Nov 19, 2002 | 04:42 PM
accordexchange's Avatar
i've actually been using the same setting on my F22B1...
Old Nov 19, 2002 | 04:46 PM
Razor's Avatar
Default Re: Vtec start point (accordexchange)
yeah 3500 seems like the sweet spot for our f22b1/f23a1/4 motors
Old Nov 19, 2002 | 06:26 PM
AccordCF4's Avatar
Default Re: Vtec start point (Razor)
What about H22A?
Does anyone got a H22A, and where is your Vtec start point?
Old Nov 19, 2002 | 07:51 PM
i just fiddled with my VAFC while driving and eventually found the sweet spot... you could try the same it might be harder since you got low and high settings to tune...
Old Nov 19, 2002 | 07:55 PM
AccordCF4's Avatar
actually I tried to set the start point back to 5500rpm, and I can feel a sudden push. Kind of like a turbo hehe.
so I guess I should set it between 5000 to 5500.
Old Nov 19, 2002 | 07:57 PM
yea the "push" is nice but you wanna make sure it's still got that smooth transition during the rpms... you can feel it when it kicks in too early and when it kicks in too late...
Old Nov 19, 2002 | 08:12 PM
yes, you want to set the crossover at the point where both cams are making the same amount of torque/power
Old Nov 19, 2002 | 08:17 PM
AccordCF4's Avatar
Default Re: Vtec start point (SOHCArchangel)
okie I'll run a few start later on tonight.
Old Nov 19, 2002 | 09:42 PM
94BlackRS's Avatar
Did u install it yourself? If so can you help me out and tell me how to access your ECU...I drive a 98 accord so it would be the same way...
Old Nov 20, 2002 | 03:08 AM
AccordCF4's Avatar
Default Re: Vtec start point (98accordv63L)
My ECU is behind the radio, and it can be accessible thru the passenger side.
Old Nov 20, 2002 | 07:04 AM
Accord_Munch's Avatar
Hey Accordexchange, are you happy with the VAFC, can you really feel the gains. I want to buy one myself, and then get my car dyno tuned.
Old Nov 20, 2002 | 04:30 PM
Default Re: Vtec start point (Accord_Munch)
i'm OK with it... for now it mainly serves as a interior decoration/accessory or light show in conjunction with my head unit... at least i was able to change my VTEC engagement point (and know when VTEC actually kicks in for once) as well as some other minor initial settings... once i get my turbo kit on, i probably will be happy... people say get SMC, Hondata, AEM, etc... but i'm pretty happy with the VAFC so far... it looks pretty damn cool.. i plan on doing 10psi with the VAFC/440 hack and hopefully i'll be happier...
chulopilong
Jul 25, 2004 07:10 AM
killa_lude
Aug 26, 2003 05:10 PM
slowazzhatch
19
Jan 20, 2003 11:34 PM
JG Luder
Sep 6, 2001 01:51 PM
