Vtec Issues
Old Jun 25, 2011 | 07:24 PM
5th Gen JB's Avatar
Default Vtec Issues
I just had my motor rebuilt and vtec would work only for about 10 min of the drive. Change oil pressure sending unit because of a leak, oil levels are up. But then there was no check engine light and and speedometer was working fine. Today i just replaced both gaskets on the solenoid. When i started the car the CEL came on. I disconnected the battery for about 10 min but that didnt work either. Then i noticed not only was my CEL on but my speedometer didnt work either. Right now i dont know what else to do and im OBD1 so i cant plugin and get a reading. Anybody have an idea?
Old Jun 25, 2011 | 08:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Vtec Issues
Since you were in the area, you may have tugged or pulled the VSS pigtail. Check to see that it is still connected. And with OBD I you can check the codes by jumping the blue two wire connector under the glove box with a paper clip. Watch how many times the CEL light blinks and get back to us. Probably code 17.
Old Jun 25, 2011 | 09:14 PM
5th Gen JB's Avatar
Thats actually what i have been thinking since i have been researching it. Not to mention i dropped a ratchet down there it took me about ten min to get out. But thanks man Im going to check it out tomorrow and i will let you know.
Old Jun 26, 2011 | 07:10 AM
5th Gen JB's Avatar
Vtec wont work if vtec is not plugged in....Ooops. I figured it out. Thanks anyways.
Old Jun 26, 2011 | 08:34 AM
poorman212's Avatar
Glad you got it....off topic: Is that "all you can eat" Catfish resturant still there in Garner?....Schroeder's or something like that....ok, so it has been 20 years, so maybe not..
Old Jun 26, 2011 | 10:05 AM
5th Gen JB's Avatar
Well i thought i got it but i guess i will have to go back and try the CEL reading. As far as the restaurant goes I think i have heard of a good Catfish place in Georgetown somewhere around here but im not sure about Gardner.
thunderboy
Jan 6, 2011 10:13 AM
Ej1Scruggs
Sep 1, 2010 11:41 AM
EK FLY
Aug 24, 2006 05:30 PM
onesikcivic
Jun 22, 2005 11:20 PM
Worangejuice
Nov 15, 2003 06:36 PM
