VTEC Controller?
Old Mar 13, 2006 | 08:43 AM
Jay84ever's Avatar
Default VTEC Controller?
I'm going to swap a H22a in my 95 Accord. One of my friends told me to get a VTEC controller, should I? And what is a VTEC controller?
Old Mar 13, 2006 | 08:48 AM
Ross 2.0's Avatar
In a Junkyard near you.
Without a controller vtec won't work since your car probably doesn't have it, All it does in simple terms is engage vtec at whatever RPM you set it to do so.
I'm a little rusty on the first year the Accord got vtec...
Old Mar 13, 2006 | 11:43 AM
HandoEX's Avatar
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">Without a controller vtec won't work since your car probably doesn't have it, All it does in simple terms is engage vtec at whatever RPM you set it to do so.
I'm a little rusty on the first year the Accord got vtec...</TD></TR></TABLE>
Uh, bad advice You don't need a vtec controller for vtec to work. A unit such as the VAFC2 allows you to change the rpm point at which vtec engages.
Old Mar 13, 2006 | 11:53 AM
NAiL05's Avatar
Default Re: (HandoEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandoEX &raquo;</TD></TR><TR><TD CLASS="quote">
Uh, bad advice You don't need a vtec controller for vtec to work. A unit such as the VAFC2 allows you to change the rpm point at which vtec engages.</TD></TR></TABLE>
What he said. Plus a VTEC controller doesnt do much. You would have better luck with a chipped ECU (P28 or P72). Plus if you do the swap you use the prelude ECU (P13) which should engage the VTEC at around 5200 or something like that wherever the stock setting is set at.
Old Mar 13, 2006 | 12:16 PM
philadd's Avatar
Default Re:
There's some misinformation going on in here...
Jay84ever, I'm assuming that you will be using the Prelude's ECU when you swap in the H22, and not the Accord's. You should, unless you run a chipped ECU. But for simplicity's sake, use the Prelude's ECU.
You don't NEED a VTEC controller. All it does is allow you to alter the rpm that VTEC engages. The only time I suggest altering the engagement is if you're on a dyno, which will let you know if it's helping or not, along with how much to change the fuel settings.
It seems you're new to this... Check out the FAQ in the Prelude forum. There are some really informative links there.
Old Mar 13, 2006 | 12:25 PM
wingback44's Avatar
Default Re: Re: (philadd)
i think 1994 was the first year accords got v-tec. cause the EX model had it i think. i think so long as the has the right ECU then the v-tec should work
Old Mar 13, 2006 | 10:29 PM
Jay84ever's Avatar
Yeah of course it's a VTEC, EX! What's the point of not have a VTEC. I'll probably use the prelude ecu, whatever the swap requires. I'm not really new at this, I just don't post much. I read a lot of posts.
Old Mar 14, 2006 | 01:41 AM
OuttaGas's Avatar
I JUST TOOK OUT MY P13 AND VAFC AND GOT A CHIPPED ECU. IT WAS THE BEST THING I EVER DID FOR THE CAR
B18c1vicrx
Nov 11, 2007 02:35 AM
baseball_aj
Honda Civic (2001 - 2005)
11
Jul 26, 2007 07:09 AM
02accord90supra
Apr 6, 2007 10:00 AM
