Transmission Compatibility: 94 tranny on 96 engine
Old 12-30-2008, 09:45 PM
The-Kid's Avatar
Default Transmission Compatibility: 94 tranny on 96 engine
Hi there. I am replacing my car's auto tranny with a used from a 94 Accord to a 96 Accord. The only reason I'm asking this is because is there any issue with the OBD compatibility? Because the 94 has obd1 and the 96 has obd2.
Sorry, I just suck at these swap things.
Old 12-31-2008, 01:46 AM
YeuEmMaiMai's Avatar
Default Re: Transmission Compatibility: 94 tranny on 96 engine
yes they are interchanegable
Old 12-31-2008, 03:06 AM
sheekdude's Avatar
Same tranny from 90-97... Good luck!
Old 12-31-2008, 04:04 AM
GhostAccord's Avatar
Are the OBD1 and OBD2 Automatic trans wiring connections different??????
Old 12-31-2008, 09:37 AM
stereo69's Avatar
you have to use your old wireing harness but all the sensors are there.
Old 01-05-2009, 03:23 PM
The-Kid's Avatar
Also regarding different year transmission, I always keep hearing updates to the transmission internals. I have a 96 and replacing it with a 94, am I at a disadvantage or its ok?
Old 01-05-2009, 03:33 PM
raceACCORDingly's Avatar
if its got lower mileage and better conditioned i dont see any disadvantage.
although id check to make sure the plugs on the harness will work. obd1 has a separate TCU that controls the tranny. obd2 the TCU is incorporated into the ECU so that portion of the harness is definitely different but im not sure about the other end in the bay.
i believe 90-91 mounts are different.
Old 01-06-2009, 09:18 PM
The-Kid's Avatar
Hmmmmm.... sounds iffy on the compatibility, but we'll see, I'm having a shop do it for me.
Also, torque convertors. I'm not sure if the used one comes with it, but what should I do if it doesn't? How often do those things get bad?
Old 01-06-2009, 09:28 PM
lexan2.2sedan's Avatar
Thats probably the reason they are changing the trans, your tq converter went out and destroyed your tranny.
Old 01-10-2009, 06:40 PM
The-Kid's Avatar
K thanks for the reply. The shop is going to find a transmission this coming monday. In the mean time, I'm doing some research on my own.
My car is a 96 Honda Accord EX which has F22B1. The only other cars I know that share F22B1's are the 2.2 Acura CL and The 4cyl Odyssey. (If you know others, please share!)
So let's say I found a transmission from those cars, would it be possible to swap in that tranny into my Accord? Thanks!!!
(I just want to open up my options to used trannies)
Old 01-12-2009, 08:44 PM
The-Kid's Avatar
Anyone know?
Proud Virginian
Transmission & Drivetrain
02-11-2011 07:08 AM
Kyle123
06-27-2009 10:56 AM
SAVIOVEGA
10-31-2008 09:07 AM
Din
03-06-2007 04:50 PM
Quick Reply: Transmission Compatibility: 94 tranny on 96 engine
