tps sensor?!?
Old Jun 22, 2009 | 06:57 PM
webbs2jzgte's Avatar
Default tps sensor?!?
i have a 90 accord. with the f22. the tps is bad causing the idle surge. is their any company who makes a tps for the car. would i be stuck drilling out the rivets and taping the tb for bolts and putting a new tps. or is everyone just replacing the tb with a used oen that has a tps on it thats good?
Old Jun 22, 2009 | 08:37 PM
H22PwrdInspire's Avatar
Default Re: tps sensor?!?
If you are having a problem with your idle surging, it sounds to me like you may actually have a problem with your Idle Air Control (IAC) valve. Check your coolant level, make sure your radiator is full and crack the bleeder valve on the thermostat housing to relieve the system of any air around the t-stat. If your coolant level is low, that will cause your idle to surge. If your coolant level is ok, you may want look into replacing the IAC valve which 9 times out of 10 will be the problem long before the TPS sensor will ever go bad.
Old Jun 23, 2009 | 05:38 AM
nysdriver's Avatar
If you do decide to replace the TPS -- it's actually not riveted: http://hondaswap.com/general-tech-ma...sor-tps-58326/
I do agree with Inspire, though. Check all the other components first.
Old Jun 23, 2009 | 07:06 AM
ok because i had a surge and i unplugged the tps and iot just stays at a high idle at about 1800. would that still be the iacv?
Old Jun 23, 2009 | 01:33 PM
Yes. I work for Honda and it is pretty accurate for me to say that I am certain it is the IAC valve. This is an infamous problem on Honda's and Acura's across the board.
Old Jun 28, 2009 | 03:13 PM
trytomake's Avatar
what if you unplug the sensor and it idles just fine my cb7 is doing the samne thing but it runs better with out the tps plugged in than not so would that make it and i replaced the IAC bout a year ago
Old Jun 28, 2009 | 03:44 PM
Targa250R's Avatar
be professional
A surging idle is caused by low coolant level, faulty IAC valve, or faulty fast idle thermo valve.
Old Jun 28, 2009 | 10:24 PM
accord3955's Avatar
well if you unplugged it...does it throws a CEL???
Old Jun 29, 2009 | 09:20 AM
yes it does
Old Jun 29, 2009 | 01:18 PM
trytomake's Avatar
well i just checked the coolant level and its ok and it does set the light with code 7 which is the tps but i would still be the IAC even though i had just replaced it
Old Jul 8, 2009 | 10:10 AM
someone told me you can clean a iacv. is that true. i might try and clean it and see if it improves
Old Jul 8, 2009 | 10:40 AM
TheMuffinMan's Avatar
He knows where you live!
IACV/FITV/TB Cleaning thread in the Accord FAQ......
Old Jul 8, 2009 | 11:15 AM
thanks. also now that i plugged everything back before cleaning the valve. my idle like starts at 2500 and just rises. like i dont have to give it gas. it just slowly rises and increases the speed
Old Jul 8, 2009 | 02:10 PM
What does your throttle cable look like? You may have loosened it or something by accident.
Did you bleed the coolant system?
I'd also go back and disassemble it and see if you neglected anything
Old Jul 9, 2009 | 03:50 AM
i will check because my throttle is real touchy. the slightest touch is like im jumping in a god damn race car and with the light touch it wants to rip off. does anyone know what it is to be torqued too
Old Jul 9, 2009 | 08:32 AM
hondamark35's Avatar
Originally Posted by webbs2jzgte
i will check because my throttle is real touchy... does anyone know what it is to be torqued too
what the throttle is to be torqued to??
Old Jul 9, 2009 | 09:16 AM
The cable? It just needs to be tight enough to where there's no slack but does not pull on the valve.
Old Jul 9, 2009 | 03:23 PM
ok i will check. if thats not the case. what should i eliminate. would the valve being tightened down to much or not be a problem. because i replaced the tb and the valve seems like that nut is tighter on it.
hadehatch
Dec 4, 2024 01:46 PM
wade9233
May 28, 2013 02:56 PM
ericstambaugh07
Jan 20, 2007 01:52 AM
AZNracerx1989
Dec 14, 2005 12:01 AM
hybrid901
May 29, 2003 07:20 AM
