throwing coded 70... help
Old Jan 1, 2006 | 07:15 AM
unrefined7's Avatar
Default throwing coded 70... help
when i started up the car this morning, the check engine light came on... i believe it's code 70? automatic transmission problems. how do i fix?
edit: it's a 2000 accord Lx (4 cyclinder) sedan by the way.
Modified by davek at 11:00 AM 1/1/2006
Old Jan 1, 2006 | 10:00 AM
unrefined7's Avatar
Default Re: throwing coded 70... help (davek)
anybody?
Old Jan 1, 2006 | 10:14 AM
BLKFLSH's Avatar
I don't have anything for a code 70. Think I read somewhere that it's a jdm specific code. Do you have a jdm ecu?
Old Jan 1, 2006 | 11:15 AM
YeuEmMaiMai's Avatar
if it is your auto trans, the [D] light should blink the code.
Google Honda ECU codes and that will give you many sources to look at.
Old Jan 1, 2006 | 04:15 PM
unrefined7's Avatar
Default Re: throwing coded 70... help (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">if it is your auto trans, the [D] light should blink the code.
that is exactly what it is... i've been googling and there's not fix for it?
Old Jan 1, 2006 | 04:21 PM
look here
https://honda-tech.com/zerothread?id=1171263
Old Jan 1, 2006 | 04:44 PM
BLKFLSH's Avatar
I see a code here 70-3 "Shift solenoid valve A stuck OFF or ON". Hope it helps.
Modified by BLKFLSH at 7:57 PM 1/1/2006
Old Jan 1, 2006 | 04:49 PM
hondadude's Avatar
The best thing you can do is get the code read with a scan tool ..there are about 5-6 'P' codes that are listed under the flash code 70; most auto parts stores will read the code for free.
10
Sep 9, 2006 12:57 PM
verbose assassin
Oct 30, 2005 03:52 PM
ckawjr
Mar 12, 2005 10:39 AM
daniel_jian
Jun 27, 2004 11:07 AM
