strange problems
Old May 23, 2002 | 08:53 AM
H23 Power's Avatar
Default strange problems
back to my friends car... 90 accord auto lx...blah blah
it seems to start up good...runs pretty good until the car warms up, then IF you stop and have the car in drive, it will die. IF you put it in neutral, it will not die.
Then, after you turn the car OFF, you cannot start it again for 30 minutes, it just cranks...but usually after about 30 min, it starts right up....WTF?
Old May 23, 2002 | 08:56 AM
p0pe's Avatar
Default Re: strange problems (01GSR)
I had a similar problem on my very first car... a 1987 chevy cavalier
the timing was way off
it needed a new timing belt i believe
Old May 25, 2002 | 01:07 PM
H23 Power's Avatar
ttt
Old May 30, 2002 | 10:47 AM
H23 Power's Avatar
uuuup...please????
Old May 30, 2002 | 10:55 AM
4doorH22's Avatar
It's gotta be something like ignition, main relay, or even the engine/tranny ground wires?
Someone else had similar symptoms and it turns out his tranny ground wire was just loose/corroded.
Old May 30, 2002 | 11:07 AM
H23 Power's Avatar
Default Re: strange problems (4doorH22)
think i checked the ground...i dunno, its just strange...
monday the car would NOT start at all
tuesday it started ALL THE TIME...over and over
wtf?
oh, monday it wasn't getting fuel to the rail...no fuel pressure...
[Modified by 01GSR, 2:07 PM 5/30/2002]
Old May 30, 2002 | 11:20 AM
2point6's Avatar
90-93 Accords are notorious for main relay failure. check
Old May 30, 2002 | 03:21 PM
H23 Power's Avatar
Default Re: strange problems (2point6)
ya know...before when the car wouldn't start we got a diff main relay...switched it and it didn't help...so we switched it back...might as well put the other one back in and see what happens with the current problems
Old Jun 1, 2002 | 03:27 PM
Chiovnidca's Avatar
Main relays very rarely cause stalling problems. When yours stalls, does it start right back up?
paysos
Jun 14, 2011 12:47 PM
Roca fella Bryan
Mar 24, 2008 01:52 PM
SoHc94
Jan 19, 2007 04:20 PM
1990 CRX Si
Apr 3, 2006 10:33 AM
AzBlackTeg
Oct 10, 2004 05:36 PM
