starter problems
Old Feb 18, 2014 | 03:23 PM
dedavis88's Avatar
Default starter problems
I have 95 auto accord just put a used transmission and new torque converter in it. It shifts fine but tried two starters and neither disengage after starting and clue what could be wrong? Thanks
Old Feb 18, 2014 | 04:37 PM
dedavis88's Avatar
Default Re: starter problems
Help anyone?
Old Feb 18, 2014 | 07:16 PM
tim73's Avatar
Have you tried the starter while out of the car? Make sure bendix kicks in and out, and it spins? Make sure bendix isnt stuck out?
Old Feb 18, 2014 | 08:19 PM
dedavis88's Avatar
I'll try that tomorrow but what of it's not working what do you do? I don't think that would be the problem with two starters?? But what could it be the wrong torque converter? I don't see how cause it shifts fine...
Old Feb 18, 2014 | 09:22 PM
holmesnmanny's Avatar
Did you swap the drive plate ? Does the tranny have the same transmission code ? What car is it from ? You may need the starter from the car that you pulled the tranny from.
Old Feb 19, 2014 | 01:40 AM
dedavis88's Avatar
No didn't swap the drive plate Trans came from exact same car I kept the starter on the Trans when I got it from the car tried it and my old one both do the same thing and codes are the same also..
Old Feb 19, 2014 | 02:12 AM
double check that that torque converter is the correct one for your car ... i hope it was installed properly
Old Feb 19, 2014 | 01:39 PM
dedavis88's Avatar
Yeah I had a shop do the labor I guess IM going to pull it myself and compare it to the old torque converter
rkmartin017
Jul 21, 2012 07:34 PM
efjones9
18
Mar 11, 2010 12:53 PM
Kusai.Nihonjin.Desu
Jan 26, 2008 08:07 PM
migs
Mar 19, 2004 09:21 PM
