squeaking from right side week after ball joint and tie rod install help please
this accord section sucks no help thanks for nothing
Re: sq*eaking from right side week after ball joint and tie rod install help please
nobody knows...where's the m*ffinman when * need him?. im gettin a similar so*nd when i go over speed b*mps
Re: squeaking from right side week after ball joint and tie rod install help please
I've found it's the sway link bushings that usually make the noise. After greasing them the noise goes away.
bump
the right side has a new sway bar end link and oem honda link u cant grease there no fittings but thenew aftermarket one does i think its coming from that new shitty autozone ball joint i took it apart greased the bottom and put everything back together and i dont hear anything now but if it starts again im goin with a oem honda ball joint like i should have .....
i was thinking maybe y clunking sounds could be the radiues arm bushing but how can i tell for sure the shocks are oem 150k on them
https://honda-tech.com/forums/showth...2#post44006952
39 views and no replys because it is so hard to read Gomar! Stick a period or three in that mess and form sentences. It will be much easier to read. And also it will not look like a third grader posted it! Did you flunk out of grade school?
bump for a loser
2003 ES1
Honda Civic (2001 - 2005)
02-20-2013 03:26 AM
briq4
07-21-2002 08:04 PM
