Snapped timing belt, 92 accord
Old 09-28-2007, 09:23 PM
deniselynn946's Avatar
Default Snapped timing belt, 92 accord
hey whats up guys. I have a 92 honda accord with the SOHC 2.2L engine. While I was driving down the road getting ready to stop i hear a humming noise and then the car shut off. So when we looked at it at the shop the timing belt snapped, the timing belt was only 5months old. Now alot of older honda techs were telling me that I could probally get away with just replacing the timing belt with the chance of a blown head. Now other techs are telling me that if I'm lucky i bent some valves but most likley blew the motor. Now can someone please tell me what the hell is true and whats not.
.....By the way I did not hear any knocking or feel any vibrations like alot of people said i would have heard/felt and also the car trys to crank over from the bottem crank...
Old 09-28-2007, 09:43 PM
SpeedDreamz.com's Avatar
Default Re: Snapped timing belt, 92 accord (deniselynn946)
time it up and put a belt on it then check the compression. that will tell you the troof.
By the way this is the DRAG RACING forum.
Old 09-29-2007, 03:46 AM
DaveF's Avatar
Default Re: Snapped timing belt, 92 accord (SpeedDreamz.com)
maybe they were on the way to the races
Old 09-29-2007, 04:22 AM
Duane_in_Japan's Avatar
Default Re: Snapped timing belt, 92 accord (DaveF)
https://honda-tech.com/zerothread/2108186
Go read this thread happening right now, should be very close to your post. Has pics too, you should have bent valves, you have an interference engine, putting a belt on (in time) and doing a compression test is an ok procedure, just dont waste time putting everything back together until a compression test and a leak down test are done.
Old 09-29-2007, 06:38 PM
DCFIVER's Avatar
Default Re: Snapped timing belt, 92 accord (Duane_in_Japan)
Will likely be ok. Saw many a t-Belt snap on those Accords..
Old 09-30-2007, 05:11 AM
Chiovnidca's Avatar
Default Re: Snapped timing belt, 92 accord (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">Will likely be ok. Saw many a t-Belt snap on those Accords..</TD></TR></TABLE>
Yep they rarely bend valves.
Old 09-30-2007, 06:01 AM
AccordEX1991's Avatar
Default Re: Snapped timing belt, 92 accord (Chiovnidca)
I bought my 91 Accord at 270k miles with a snapped timing belt for $125.
Bought a new timing belt, installed it, and did a compression test, voila, 175 psi across the board.
Replaced the rod bearings for preventive and it is still on the road with &gt;300k miles.
Old 03-21-2008, 06:44 AM
AnotherEJ's Avatar
Default Re: Snapped timing belt, 92 accord (AccordEX1991)
I just picked up a 92 with a snapped T belt and 226 on the clock. I hope I can do the same and it only be the belt.
Old 03-21-2008, 06:22 PM
808S2000's Avatar
I don't think the accords have a interference fit engine. I seen some t belts snap with no damage. The civics on the other have will probally always have damage
deniselynn946
10-30-2009 04:48 PM
deniselynn946
11-14-2007 07:08 PM
deniselynn946
09-30-2007 05:51 AM
deniselynn946
09-29-2007 12:07 AM
zoro5
05-13-2007 07:23 PM
Quick Reply: Snapped timing belt, 92 accord
