service engine code
Old Oct 9, 2006 | 01:46 PM
lilyeym's Avatar
Default service engine code
hey what's up guys new to the group ..ofcourse have a question i have a 1999 cl acura which u know its an accord.. 4cyl manual 2.3 vtech i have a p1250 code but can't find it on the manual.. the real one manual i mean.. i was hoping u guys can help me out
Old Oct 9, 2006 | 04:20 PM
Miracle's Avatar
Default Re: service engine code (lilyeym)
P1250 Lack of Power to FPRC Solenoid.
I am assuming an FPRC is a fuel pressure regulator. You will need to pressure test and perform a leakage test on the regulator. That would be my first guess.
The only other thing I could think would be a fuel pump/pressure sensor problem.
Old Oct 10, 2006 | 04:31 PM
lilyeym's Avatar
Default Re: service engine code (.Red.EM2)
how can i tested sorry still i bit new with cars..thanx for the info though
Old Oct 10, 2006 | 04:37 PM
Miracle's Avatar
You need to put a vacuum pump on the FPR, and see if it holds the vacuum by the gauge on the pump. If it doesn't, it needs to be replaced.
Old Oct 16, 2006 | 04:56 PM
lilyeym's Avatar
could that be a problem for hard startring...its a brand new starter..
Old Oct 16, 2006 | 05:36 PM
H2290's Avatar
It is possible if the correct amount of fuel is not being used at start that hard starting could occur. And it's VTEC for future reference. An acronym for Variable Valve Timing and Electronic lift Control.
Old Oct 25, 2006 | 10:55 AM
lilyeym's Avatar
Default Re: service engine code (H2290)
well that's been changed the FPR and i still get the same result in starting anything else i should check?
Jahmani
Nov 9, 2018 03:53 PM
91 luder
Aug 28, 2012 04:16 PM
-.1234P312.-^EK_SI^
Sep 8, 2008 07:24 PM
89 CRX SI
Apr 22, 2003 03:22 PM
monsoon
Nov 21, 2002 08:54 PM
