Replacing Caliper Help
Old Jan 13, 2006 | 09:44 AM
bluskye's Avatar
Default Replacing Caliper Help
1994 Accord EX
I am replacing a front driver's side caliper (I picked one up used) after I put in a new seal kit in for it. I had some questions:
1. Do i have to bleed the entire brake system again, or just that one wheel?
2. How do I keep the fluid from oozing all out when i disconnect the brake line from the caliper and drying out the master cylinder?
Any tips on the precedure?
Old Jan 13, 2006 | 10:28 AM
iam7head's Avatar
Default Re: Replacing Caliper Help (bluskye)
1)you do not need to bleed the whole system ONLY if you do the following.
2)use a locking clamp to clamp down the brake line(just couple of inch from the caliper, use a piece of rubber if you worry about the tooth of the clamp damaging your brake line. Bleed it after all work are done
this is how the shop do it.
remember don't leave it clamp down brake line for a week or something, do it in timely manner
Old Jan 13, 2006 | 10:33 AM
bluskye's Avatar
Default Re: Replacing Caliper Help (iam7head)
Thanks, I was thinking the same thing but needed verification. The swap should be fairly quick (minutes) since the two calipers will be right next to eachother for a quick swap of lines.
Thanks!
Old Jan 13, 2006 | 10:50 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluskye &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I was thinking the same thing but needed verification. The swap should be fairly quick (minutes) since the two calipers will be right next to eachother for a quick swap of lines.
Thanks!</TD></TR></TABLE>
no problem, just make sure you don't twist the clamp once it's locked. or the brake hose will have blister
96Formula6spd
Aug 25, 2011 05:39 PM
scotter031
Jan 30, 2008 06:48 PM
5thGeneration
Dec 4, 2007 08:51 PM
JDM_EK_JOE
Apr 14, 2006 11:44 PM
avs
Jul 19, 2002 08:56 PM
