Comp4 4th gear problems
Old Jul 26, 2006 | 10:10 AM
allmotorhatch's Avatar
Default Comp4 4th gear problems
I've had no luck getting this car to engage 4th gear at any rpm higher then 7000.
I was wondering if any one else has had similar rpm related problems?
I have tried several trans setups, master cylinders, slave cylinders,syncros, gears. I let a buddy take the car for a pass just to make sure it wasnt me as a driver, and we had the same results. I am currently running a twin disc, and the clutch is the last part I have not changed.
Any ideas or suggestions? Jared
Modified by allmotorhatch at 11:23 AM 7/26/2006
Old Jul 26, 2006 | 10:18 AM
Supernatural's Avatar
Default Re: Comp4 4th gear problems (allmotorhatch)
whats the problem?
Old Jul 26, 2006 | 10:23 AM
SIXTY's Avatar
Default Re: Comp4 4th gear problems (Supernatural)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supernatural &raquo;</TD></TR><TR><TD CLASS="quote">whats the problem?</TD></TR></TABLE>
Old Jul 26, 2006 | 10:34 AM
Default Re: Comp4 4th gear problems (sixty-seven point six)
The car will not go into 4th gear at any higher rpm then 7000.
Old Jul 26, 2006 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorhatch &raquo;</TD></TR><TR><TD CLASS="quote">I am currently running a twin disc, and the clutch is the last part I have not changed.
Modified by allmotorhatch at 11:23 AM 7/26/2006</TD></TR></TABLE>
I would start with the clutch...
I smashed a pilot bearing and the clutch would go in at low rpm but would shift when i tried to push it ....Mis-shift city
check the linkage to see if it is bent....
Old Jul 26, 2006 | 07:29 PM
DaveF's Avatar
adjust the pedal ?
Old Jul 27, 2006 | 12:20 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supernatural &raquo;</TD></TR><TR><TD CLASS="quote">check the linkage to see if it is bent....</TD></TR></TABLE>that's my guess!
Old Jul 27, 2006 | 05:05 AM
DaveF's Avatar
Default Re: Comp4 4th gear problems (smokey2.0)
he has already replaced the linkage with a brand new one
Old Jul 27, 2006 | 06:00 AM
smokey2.0's Avatar
Default Re: Comp4 4th gear problems (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">he has already replaced the linkage with a brand new one </TD></TR></TABLE>have you taken the transmission apart? check the shift fork/ selector/ synchro slider, and the clutch while you have the transmission off! i have seen this happen in 5th gear, and it's a combination of a worn shift fork, and synchro slider! good luck!
Old Jul 27, 2006 | 06:06 AM
DaveF's Avatar
ive offered to take a look but i havent seen it yet.
Old Jul 27, 2006 | 06:10 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">ive offered to take a look but i havent seen it yet. </TD></TR></TABLE>let us know what it looks like, when he opens it up! from what i have delt with, a broken PP will do that, but i'll happen in all gears! it must be inside the transmission, specially since he's been through all the other probable causes. good luck
Old Jul 27, 2006 | 06:18 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">let us know what it looks like, when he opens it up! from what i have delt with, a broken PP will do that, but i'll happen in all gears! it must be inside the transmission, specially since he's been through all the other probable causes. good luck </TD></TR></TABLE>
thanks man, Jared need all the luck he can get with these trans. he been through alot already, nothing but problems/broken parts. hopefully something will come together by this weekend. if not, i guess we'll be fixin it at the track
Old Jul 27, 2006 | 06:33 AM
B18C1CYA's Avatar
What syncros are you running ?? and I would adjust the peddel , and then if that dont work time to pull the trans and take it apart , might have bent forks or the syncros are just to worn out , even the slide could be bad , but you can save them with a small file to get you by , just cus they cost some money ,
Old Jul 27, 2006 | 09:25 AM
swapit's Avatar
Default Re: Comp4 4th gear problems (B18C1CYA)
he has tried a couple diff trans all looked good except for the first quafie one.we have tried diff shift forks,and sliders and still cant get 4th.got a fresh b16 trans was clean inside only change was the quafie dif and the 4.9 final,sent the comp clutch twin disc back and they shaved the discs down they said they were too thick.and still the same problem.think we are goin to try puttin a single disc back in to see if thats works
Old Jul 27, 2006 | 09:38 AM
Default Re: Comp4 4th gear problems (swapit)
I had the clutch overnighted, it came in this morning. I'm gonna pull the trans and swap clutches tonight and then back to Atco Friday. I would love to make a solid full pass this weekend at NOPI
Old Jul 27, 2006 | 09:53 AM
AllMotorMark's Avatar
i hear ya man i am going through some of this **** now, but worse thing is you have to take it down the track for it to happen
Old Jul 27, 2006 | 11:03 AM
crxh22a4's Avatar
Default Re: Comp4 4th gear problems (AllMotorMark)
this happened to me the linkage was bent, $200 and the car ran great
Old Jul 27, 2006 | 11:18 AM
B18C1CYA's Avatar
so this started happening after you put in the twin disc ???
Old Jul 27, 2006 | 12:18 PM
This is the second set of new linkage I have tried, The twin disc is the only clutch I have ran in this car.
Old Jul 27, 2006 | 02:17 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorhatch &raquo;</TD></TR><TR><TD CLASS="quote">I break transmissions... and now breaking windows</TD></TR></TABLE>
LOL
Old Jul 27, 2006 | 04:29 PM
how did he break a window?
Old Jul 28, 2006 | 04:03 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supernatural &raquo;</TD></TR><TR><TD CLASS="quote">how did he break a window?</TD></TR></TABLE>
with his fist
Old Jul 28, 2006 | 04:19 AM
seen4ever's Avatar
sounds like a clutch issue, adjust the pedal
Old Jul 28, 2006 | 10:13 AM
Default Re: Comp4 4th gear problems (seen4ever)
The new clutch is in, going to Atco tonight
Old Jul 28, 2006 | 01:35 PM
swapit's Avatar
diff was a late night,hope it works
p.s that new window sure was clear
