ticking sound in motor accord??
Genetically Gay
ticking sound in motor accord 91 ex??
when i start the car and let it idle.for like 10sec.i hear this ticking sound on the motor?is not that loud?what do guys think it causein the sound?looks like is coming from the motor.and today i got bad news my friends 94 accord got stolen from the mechanic shop?damn i don't even feel like takin my car to the local shop...
Genetically Gay
Re: (TheMuffinMan)
had the car for 7months now.when i first got it.was'nt making the sound.it just started about 1month ago..yes i been keeping up with the maintance like oil change about 2months.valve adjustment?how to fixed it?do i need special tool?
Genetically Gay
Re: (TheMuffinMan)
has about 250k miles.don't know how long previous owner kept on maintence all i know was when i change new oil it was hella black color.no cel light.i think is still runnin the stock waterpump and timing belt..only problem is ticking a lil bit.
Re: (KILLAB17VTEC)
It's either a loose valve or piston slap.
Then again, it could be worn out bearings in an accessory drive.
Loose valve can be easily remedied, piston slap is going to mean rebuild.
How much do you have tied up in this little car? If it were me, and I had less than $1000 in it, I'd just drive it until it finally died, but if I wanted to fix it, I'd go buy a junkyard motor, rebuild it, then switch 'em out one weekend.
You could "just get by" by going with a heavier weight oil, (10W-30 to 10W-40) and see if that helps it but you would just be prolonging the inevitable.
Re: (The_Caged_Bird)
I found that putting 10w30 in at the last oil change has quieted my car (1992 Accord) considerably. I figure that after 168k, things would be worn enough to warrant a thicker oil.
Change that timing belt! It's an interference engine!
Ari
Ari
SlowSOHC-T
10
04-06-2014 03:17 PM
danny_379
10-11-2012 02:32 PM
wfis5202
02-19-2011 08:14 PM
