quick question..
Old Apr 22, 2008 | 10:45 AM
boostedsupra's Avatar
Default quick question.. base timing?
i did a quick search, but couldn't find what i needed
anyway, can someone tell me what to jump, to set my base idle? is it the blue connector ,in the pass kick-panel?
TIA
Modified by boostedsupra at 11:58 AM 4/22/2008
Old Apr 22, 2008 | 12:32 PM
really? 20 views and nothing?
Old Apr 22, 2008 | 06:36 PM
02 accord's Avatar
Default Re: quick question.. base timing? (boostedsupra)
If your title was more descriptive than "quick question," then you would most likely get more replies with less views. But since people don't know wtf you're going to ask, they have to look.
Old Apr 22, 2008 | 06:39 PM
TheMuffinMan's Avatar
He knows where you live!
What to "jump" for your base idle?
I can say I've never heard of that. What are you trying to do? If your idle is high you can play with the adjustment **** on the throttle body or if that doesn't work follow the FITV/IACV/etc cleaning thread
Old Apr 22, 2008 | 06:54 PM
GhostAccord's Avatar
It's a Honda Accord you don't need to jump anything to set the base idle. Your thread title states that your looking for base timing????
here is a quick how to for the base idle:
1. Start your car and hold idle @ 2500-3000rpm and get it up to operating temp... cooling fan cycles
2. Turn off ignition
3. Unplug IACV
4. start car and adjust idle to spec using idle speed screw on face of throttle body (550 ±50 RPM IIRC)
5. turn off car plug in IACV
6. Reset ECU - pull backup fuse or disconnect - terminal for 30sec
7. Start car without load conditions for 1-2 minutes (no throttle)
Your done!
FYI, try to be a bit more descriptive in your thread titles
The blue connector that you referred to is the SCS connector with GRN/BLU & a RED wire. You jump that to retrieve codes from the ECU aka diagnostics mode. While in diagnostics mode that is also how you check/set your base timing.
Modified by GhostAccord at 12:05 AM 4/23/2008
Old Apr 23, 2008 | 05:44 AM
Default Re: quick question.. base timing? (GhostAccord)
wow. that was semi informative..
i found the proper procedure in the honda manual. the timing marks are on the flywheel, and there's a plate on the bellhousing.
FYI , you never ,EVER turn that idle-stop screw. ever.
Modified by TouringAccord at 12:42 PM 4/23/2008
Old Apr 23, 2008 | 06:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsupra &raquo;</TD></TR><TR><TD CLASS="quote">wow. that was semi informative..
i found the proper procedure in the honda manual , i dl'd from hondaaccordforums.com. the timing marks are on the flywheel, and there's a plate on the bellhousing.
FYI , you never ,EVER turn that idle-stop screw. ever. </TD></TR></TABLE>
Go back to reading your Honda certified shop manual, like the one I have, and read the part about setting base idle. The only way to adjust it is by touching that screw.... thanks for letting me know that I shouldn't touch it though. I am quite capable of working on my own car. "Semi informative"......Your the one looking to be spoon fed the info
Oh yeah there is a big difference between base idle and base timing as well... maybe you should make up your mind what it is that your looking for before you ask a different question in your post than what is in your thread title..... or were you looking for both procedures..... That I gave you step by step out of the shop manual...lol
Thread Title
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsupra &raquo;</TD></TR><TR><TD CLASS="quote">quick question.. base timing?</TD></TR></TABLE>
Thread Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsupra &raquo;</TD></TR><TR><TD CLASS="quote">i did a quick search, but couldn't find what i needed
TIA </TD></TR></TABLE>
Modified by GhostAccord at 11:17 AM 4/23/2008
Old Apr 23, 2008 | 09:34 AM
Modified by TouringAccord at 12:42 PM 4/23/2008</TD></TR></TABLE>
Actually butter cup, yes, yes you can adjust it.
That's why it's there. For fine tuning the idle.
Old Apr 24, 2008 | 04:15 PM
tpot90's Avatar
Default Re: quick question.. base timing? (TheMuffinMan)
PWNED!!!!
dont try to argue with someone about their answers that YOU asked about.
dave585
Mar 17, 2008 07:54 PM
L_K
Jun 30, 2007 09:48 AM
integra714
May 18, 2005 07:38 AM
DelSolSi93
Sep 5, 2004 08:27 PM
