Quick question
Old Jul 9, 2002 | 01:42 PM
n0b0dy's Avatar
Default Quick question
Well I drive an 88 accord, and i had 3 lugs in the front right wheel because my friend snapped one when tightening them... I heard a clicking noise coming from the right shaft in the front, so I thought it was the lugs being loose. I then tightened them and snapped another one, so now 2 are snapped in half inside. I was wondering if its even drivable... or worth it. And how should i go about fixing this? Can i do it myself? BTW the ones that are still there are good... they are opposite from eachother as well. God dammit, I just added some stuff to my car too... any help is appreciated...
n0b0dy
Old Jul 9, 2002 | 02:14 PM
4doorH22's Avatar
Default Re: Quick question (n0b0dy)
DUDE you shouldn't even be driving with 3 lugs. You need all 4.
You're going to have to remove the wheel remove the hub, and then replace the broken studs.
Old Jul 9, 2002 | 02:25 PM
n0b0dy's Avatar
Default Re: Quick question (4doorH22)
Where should I get the stud replacements? Junk yard?? Well hmm I need this done quick, i have to work tomorro night, thanks though.
Old Jul 9, 2002 | 02:27 PM
sung's Avatar
honda dealership, they're like 3 bucks a peice.
Old Jul 10, 2002 | 01:14 PM
n0b0dy's Avatar
Default Re: Quick question (sung) how do i put them on?
I managed to remove the brake assembly, including drum/disc. I can not get the final plate out that has the studs in them. I was able to remove the large nut (had to use a 1 1/4" wrench as I don' t have anything that big in metric). I can't get the pate out to remove the broken studs.... what shall I do? (any links to an exploded view with details, would also be appreciated! )
Old Jul 10, 2002 | 02:46 PM
89_LXi's Avatar
Default Re: Quick question (sung) how do i put them on? (n0b0dy)
Maybe this will help some...
http://www.hondaautomotiveparts.com/...KLE-BRAKE+DISK
I'm not sure of the details though. But I'd say one of the first things you need to get is a torque wrench, hehe. Only 80 ft/lbs on those lugs If you're hearing a clicking from the front end (especially in turns) it's most likely the CV joints going out.
Old Jul 10, 2002 | 06:50 PM
n0b0dy's Avatar
Thanks Jared, I got it
uncleben
Feb 12, 2009 06:43 PM
_Keith_
Aug 1, 2008 12:16 PM
JJ's civic
Sep 29, 2006 05:01 PM
bfitz
15
Aug 9, 2005 11:55 PM
blaster834
Oct 6, 2004 12:40 AM
