quick engine bay wiring question(h22 swap)
Old Apr 3, 2012 | 05:11 PM
hindelk's Avatar
Default quick engine bay wiring question(h22 swap)
So i pulled the h22 out of my 94 accord to freshen it up and went and put the motor back in and now came to realize i forget which wire goes where on 3 similar plugs...if i remember corectly the plug blue with yellow stripe and white with yellow stripe wires from the injector harness go to the iat sensor on the side of the intake manifold....and then which wires go where on the harness closest to the passanger side....2 plugs same style...one with red wire yellow stripe and green wire with blue stripe.......then a plug with a black wire with a blue stripe and yellow wire with black stripe....
Iv had the motor out for a few months so i cant remember for the life of me what was what...thanks in advance
Old Apr 3, 2012 | 06:13 PM
Greenflashlight's Avatar
Default Re: quick engine bay wiring question(h22 swap)
There is info on the sensors in the faq section. Just refer to the swap guide for h22 and it will list the sensor locations and color wires.
Old Apr 3, 2012 | 07:19 PM
hindelk's Avatar
Ok got one question they didnt answer...what is the plug that comes off. The injector harness its a black wiith yellow stripe and white with yellow stripe.....turns out i had that pluged into the iat and wasnt right
Old Apr 3, 2012 | 08:16 PM
GhostAccord's Avatar
Are you sure that the first set of wires that you mention is BLU/YEL & WHT/YEL? The only BLU/YEL wire on the 94 Accord engine harness is paired with a BLU/GRN wire and they are for the CKP sensor in the distributor.
If they are BLK/BLU & WHT/YEL wires = Fuel Injector Air control solenoid (FIA) Not used on the H22 engine.
BLK/BLU & YEL/BLK wires = Idle Air Control Valve (IACV)
RED/YEL & GRN/BLU wires = Intake air temp sensor (IAT)
Old Apr 3, 2012 | 08:36 PM
Basik_One's Avatar
Pictures might also help others see exactly what you are talking about.
Old Apr 3, 2012 | 08:59 PM
turboh22a1's Avatar
thats the idle air control valve, or atleast that what mine is because i just deleted mine
DC2LURKER
Aug 2, 2014 12:10 AM
Brownjd
Feb 13, 2011 07:32 PM
simplypinoyy
Jul 13, 2008 03:23 PM
jbell
Apr 23, 2005 02:44 PM
01IntegraSE
Feb 3, 2003 06:10 AM
