Quick A/C Question
Old Jul 20, 2007 | 09:31 PM
knightrider2000's Avatar
Default Quick A/C Question
Hey Guys,
Got a quick question.. On a 2003 Honda Accord V6 6spd with the automatic a/c, what should the high, and low sides of the a/c system running at? i am at 22/150 right now... To me the high side seems perfect, and the low seems about 10 pounds to low.. But this is my first honda, so i am not sure how they run.....I had always = thought low 30's was normal.. It was about 95 degrees today, and not much sun.... If That helps any...
Thanks
Matt
Old Jul 21, 2007 | 04:38 AM
AccordEX1991's Avatar
Default Re: Quick A/C Question (knightrider2000)
If it was 95F outside when you took the readings, system is undercharged.
Was the suction line sweating? It should sweat up to the compressor.
Old Jul 21, 2007 | 09:26 AM
Default Re: Quick A/C Question (AccordEX1991)
No it was "cool" to the touch.. not cold or even cold enough to sweat by any means.. but the compressor was not cycling in and out it was running continuously. What should ideal pressures be at about that temperature?? From what i have always seen they should be in the low 30's but that was'nt on honda's, so im not sure how they run....
Old Jul 21, 2007 | 12:31 PM
You should be around 30psi or about 35F temp to prevent evaporator from freezing up.
If it is at 22psi, refrigerant temp is at 25F and may cause the evaporator to freeze up while cruising.
Old Jul 21, 2007 | 05:00 PM
hondadude's Avatar
This chart is the truth, the whole truth, and nothing but the truth;
http://img460.imageshack.us/im...i.jpg
Ambient temp is checked at the front bumper in front of the condensor
lmgsr
Sep 19, 2008 09:10 AM
S2KJ55
Honda S2000
Jun 12, 2006 09:56 AM
turbo_b16_ex
Jul 26, 2005 08:21 AM
adictionbass
Jan 18, 2005 04:28 PM
