A/C QUESTION
A/C QUESTION
A/c Question
I HAVE A 96 CIVIC COUPE EX THE A/C WAS NOT BLOWING COLD (THE COMPRESSOR WAS KICKING ON), BUT THIS MORNING THE COMPRESSOR KICKED ON AND THE A/C WAS COLD SO I PUT THE GUAGES TO SEE IF IT WAS NEEDING FREON AND IT WAS IN THE LOW 30s PSI ON THE LOW SIDE AND IN THE 150s IN THE HIGH SIDE. I ADDED A 12oz CAN OF FREON AND ON THE LOW SIDE WAS AT 31 PSI AND THE HIGH SIDE WAS AT 223 PSI. SO I KNEW THERE WAS SOMETHING WRONG. I TURNED OFF THE CAR FOR A WHILE AND KNOW THE COMPRESSOR WON'T TURN ON. I CHECKED AND THE FAN TURNS ON AND THE COMPRESSOR HAS POWER GOING IN TO IT.
I'M GUESSING THE COMPRESSOR IS GOING BAD, WHAT DO YOU GUYS THINK.
THNX IN ADVANCE HT
THNX IN ADVANCE HT
I Just Went Out To The Car And The Compressor Turned On And The A/c Is Cold!? I'm Sure In A Little While It Won't Turn On.
What Could It Be??
What Could It Be??
Re: A/C QUESTION (lmgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmgsr »</TD></TR><TR><TD CLASS="quote">A/c Question
THNX IN ADVANCE HT </TD></TR></TABLE>
take it to a professional and have them check it out. it should be free..
arielb1
07-15-2017 04:43 PM
