Question
Old Aug 25, 2008 | 03:41 AM
Jcshort21's Avatar
Default Question
I have a 1992 Honda Accord EX 5 speed. My pro. is that when i get on the highway for about 5 miles the check engine light comes on and gives me a code 43 well i was told that a 43 was O2 so i changed it twice. It still ain't fixed i can drive around town all day and no light. I think that the cars exhaust is very rich it will burn my eyes if im back while its running. What controls the amount of fuel the car gets? I was also told that it was the IAC sensor but from reading on here its not. Any help would be great the gas mileage is KILLING ME!
Old Aug 25, 2008 | 03:48 PM
Mr Yamada's Avatar
Default Re: Question (Jcshort21)
Fresh NGK sparkplugs?
Valve adjustment?
FPR diaphram split? [raw fuel in vacum line]
Injector leakdown test?
code 43 actually means the O2 sensor is reading unburned oxides.
[engine running rich]
Old Aug 25, 2008 | 04:19 PM
Jcshort21's Avatar
Default Re: Question (Mr Yamada)
Thanks for info. The car was just tuned up plugs, wires, air filter. What is the FPR diaphram? Where is it located? How hard is it to replace? How much does it cost?
Old Aug 26, 2008 | 10:39 AM
punaboy55's Avatar
does the car run fine when the light turns on?
Old Aug 26, 2008 | 04:38 PM
Jcshort21's Avatar
Default Re: (punaboy55)
Yea The car runs fine with lights on.
Old Aug 26, 2008 | 06:43 PM
dtapia's Avatar
Default Re: (Jcshort21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jcshort21 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for info. The car was just tuned up plugs, wires, air filter. What is the FPR diaphram? Where is it located? How hard is it to replace? How much does it cost?</TD></TR></TABLE>
fuel pressure regulator =fpr
Old Aug 26, 2008 | 08:32 PM
mavvrik's Avatar
Check and make sure the 02 is properly connected. Since you're OBD1 if your disconnect your 02 or mess it up you could throw the car off and make it run funny (lean ot rich). Check the timing as well. G/L
Old Aug 26, 2008 | 08:37 PM
Jcshort21's Avatar
Default thanks
Thanks I will give it all a look in the morning
Old Aug 27, 2008 | 07:13 AM
Jcshort21's Avatar
Default Re: thanks (Jcshort21)
I went and ordered the Fuel Pressure Regulator for the Honda. $64.99 I saw a video on youtube about the FPR. The examples he gave were what I was having. Will we see in the morning when part gets here.
thatguamanionkid
May 16, 2009 11:13 AM
93 hoopdy
Apr 28, 2008 08:41 AM
fitbmx86
May 20, 2007 04:59 PM
98IntegraLSNonVtec
Aug 4, 2006 12:49 PM
MaaseyRacer
Jul 30, 2004 04:27 PM
