Proper voltage from TCU-1991 Honda Accord LX
Trying to troubleshoot correct voltage coming out of TCU- since I can't seem to find a schematic showing
correct voltage for each pin. Are they all 12 volts or is there a variance on any of them. When testing the
the first set of connectors on the firewall side there seems to be approximately 12 pins (guesstimate)
11 of the 12 pins registered 12 volts with one 2 volts. Is it safe to assume there is a problem with the TCU?
Thank you.
Thank you.
