Problem Car continued
Old Jan 15, 2012 | 02:08 PM
Rfisherxo's Avatar
Default Problem Car continued
Yesterday my car alarm went off for no reason. After turning it off, I started on my way home. My car(1995 Honda Accord) was bumping up and down. It was not the tires. I also wasnt able to go over 20mph, even when I stepped harder on the gas pedal. Eventually, I was able to go 40mph. I finally got home after driving 10miles under the speed limit. I took my car around the block today to see if it was still acting weird.....it was. Whenever i accelerate, teh gas pedal just feels so weird. It feels kinda of tight. There is obviously something wrong with my acceleration, but idk what. It is not hard to push down on the pedal. It feels as if pressure is building up inside the accelerator as I push down. And the amount I push on the gas, barely changes the speed of the car. .............
And this all would happen while im at the inspection station. Yea...so the only day my car decides to be stupid is that day. so that was great. So I need to get it fixed asap so I can go back through inspection. if any1 has any ideas on what may be wrong with my car then it would be very helpful.
Old Jan 15, 2012 | 04:41 PM
lazlong's Avatar
Default Re: Problem Car continued
Sounds like it went into limp mode. That means there's something wrong and the computer only lets it run 20mph/3000 rpm-ish so you won't ruin the engine or be stranded.
Read this and post any codes you get: http://check-engine-light-codes.blog...retrieval.html
EAF2014
Honda Accord (2013 - 2015)
Feb 2, 2018 04:54 AM
Chief Brody
May 11, 2007 08:17 AM
fridayfred3p
Dec 31, 2005 08:40 AM
byronl
10
Sep 26, 2005 12:22 AM
