Problem with air
Old May 17, 2004 | 11:49 PM
sultan_8837's Avatar
Default Problem with air
hi all
i have a problem that when i go over 70 m/h there wil be a lot of noise due to air specialy from the front doors.
Have any of you face a problem like this and if it's so how does he fix it?
that' all.
Sultan
Old May 17, 2004 | 11:53 PM
John Gordon's Avatar
Default Re: Problem with air (sultan_8837)
What year is your car? Rubber gets stiff with age, and simply doesn't seal as well.
Old May 18, 2004 | 08:05 AM
propwdialogue's Avatar
Default Re: Problem with air (John Gordon)
Yeah, you just got bad seals on your doors. Its a pretty easy fix, you can either buy new strips, or there are little kits out there that can just repair the trouble areas. a way to find the areas where you are getting leakage is to close a dollar bill in the door and slide it all around the door and the places where it feels loose are places that you have a bad seal.
Old May 19, 2004 | 12:19 AM
thanks alot John Gordon and prowdialogue
My car is 1997
Actually i found the little jits you mintioned prowdialogue but i said it's better to chech if there is a nother solution
Thanks again
Old May 19, 2004 | 12:20 AM
My car is 1997
Actually i found the little kits you mintioned prowdialogue but i said it's better to check if there is a nother solution
Thanks again
Johnpolk01
Honda Civic (2001 - 2005)
Mar 8, 2013 05:24 AM
retro1
Acura TSX
Mar 11, 2009 09:34 PM
Paprika
Jan 16, 2005 05:38 PM
Son99ek
Dec 12, 2004 08:25 PM
vtec69
10
May 20, 2002 06:45 AM
