Power window problem
Old Sep 28, 2003 | 02:24 AM
EndlEEsss's Avatar
Default Power window problem
The front passenger automatic window rolls up and down perfectly fine with the front passenger window switch.
However, I can only roll down the front passenger window with the driver side switch. It wont roll up with the driver switch.
does anyone know what the problem is?
Thanks
Old Sep 28, 2003 | 03:23 AM
bill-71SS's Avatar
Default Re: Power window problem (EndlEEsss)
master switch sounds like it is bad.
Old Sep 28, 2003 | 05:48 AM
NathanMorris's Avatar
Default Re: Power window problem (bill-71SS)
Either the switch is bad, or the little switch that is for like, child protection or whatever has been switched. On the 92-93 Model (I'm not sure what model you have), there is a very large "rock switch" running perp. to the door on the master switch set........Try toggling that, and see if it works after that. I've done that before.....you'll feel kinda silly afterwords, but hopefully that's your problem - lot cheaper to fix - well, if your pride doesn't suffer too much - I know I felt silly.
Hope this helps!
- Nathan
Old Sep 28, 2003 | 03:58 PM
EndlEEsss's Avatar
Default Re: Power window problem (92Lx)
its a 96 accord
where is the master switch located at?
Old Apr 17, 2015 | 01:46 PM
canvasmaker's Avatar
The master switch is the window control on the drivers door. It is called the master because it controls not only the driver door window, but all other windows as well.
Good luck
Old Feb 23, 2023 | 03:46 AM
1997StillRun's Avatar
Well I have the same problem driver side window goes down ,but dont go up I spray WD40 2 years ago it work till now. So I had to swich the up and down wires and it when up.
cshipman
Honda CR-V & Element
Oct 16, 2018 06:42 AM
Plinko
Honda Civic (2001 - 2005)
Aug 9, 2014 07:52 AM
einzelherz
Aug 26, 2013 06:41 AM
ramoneguru
May 20, 2006 02:47 PM
