power window issues....
Old Sep 14, 2006 | 01:26 PM
mark_is_gay's Avatar
Default power window issues....
its a 91 accord wagon ex. passenger side window is down, and wont roll up. I have checked the fuses and all seem to work. When i push down, the power is there and the window wants to go down. But when i press up, nothing happens. IS the motor dead? i am not sure how to solve this problem.
Old Sep 14, 2006 | 02:11 PM
Default Re: power window issues.... (mark_is_gay)
ttt
Old Sep 14, 2006 | 02:16 PM
honda_kid42's Avatar
have you tried from both the passenger side and driver side to see if either one will get it up??? if neither one work i would say its prolly the motor or the window came out of the track...
Old Sep 15, 2006 | 09:40 AM
Default Re: power window issues.... (honda_kid42)
well both driver and passenger buttons, wont bring it up. Press down, and i hear it working. I press up and its dead. would that mean the motor is out?
Old Sep 15, 2006 | 10:42 AM
Jay84ever's Avatar
It's the Accord curse!! My drivers' side window does it all the time. I was told it was the window motor going bad.
Old Sep 15, 2006 | 10:47 AM
HRDCORD's Avatar
You need to replace the window relay. Sadly this involves picking up the entire assembly. When I replaced mine in my first 5th gen I found Honda sells them for around $110, last I checked. Find it in the junk yard.
Old Sep 15, 2006 | 11:43 AM
Default Re: (HRDCORD)
so its a window relay? i will try and hit up the junkyards 2morow and search for one. Hopefully it will get the window working again, driving around at night is a bit chilly. thanks for the help guys
Old Sep 15, 2006 | 09:14 PM
Mjfan12's Avatar
make sure the door wiring is ok. in older cars moisture gets into the boot between the body and the doors and tears up the wires.
my pass window never workd and i looked at the fuses, and motor, and realized it was the wiring, i took it apart and saw 3 wires broken including ground.
maybe ground is mesed in yours.
I havent repaired it yet, too lazy but it 99.9999% my wires, haha
Old Sep 16, 2006 | 08:24 AM
Honda-Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRDCORD &raquo;</TD></TR><TR><TD CLASS="quote">You need to replace the window relay. Sadly this involves picking up the entire assembly. When I replaced mine in my first 5th gen I found Honda sells them for around $110, last I checked. Find it in the junk yard.</TD></TR></TABLE>
DO NOT replace any relay it will be a waste of your money and time.........
you need to diagnose before you start replacing parts..
remove the door panel, get a test lite,, on the motor plug there are 2 wires .one has power going up the other provides ground, when going down the polarities are reversed
so get a paper clip, hook up the test lite to both wires and push the window switch up and down and chk for power . if the test lite illuminates on both wires,, than the wiring and everything going to motor is ok,,,,,which means that you got a bad motor
if test lite does not lit up going up, you could have a bad window up circuit in the switch, bad wiring ,,or bad power window control unit
let us know
Old Sep 16, 2006 | 10:22 AM
Default Re: (Honda-Master)
thats great help. i will be working on it today, i will let u guys know whats up. thanks
Old Sep 17, 2006 | 06:02 PM
Default Re: (mark_is_gay)
The switch on the driver side, does not work as well. I push up and down, and nothing happens. Only the passenger side button pushed down works. NOt up. I am gonna try to hit up a junkyard and see what i do. ANyone know what this means.? thanks
Dub C
Oct 8, 2010 05:49 PM
damdash
Jun 24, 2009 05:08 PM
xkrakenx
Apr 24, 2008 06:12 PM
professorman
Nov 17, 2004 10:54 AM
tomkocz
Aug 30, 2004 09:23 PM
