Pinout for Idle air control valve 2002 accord v6
What is the pin out configuration for the idle air control valve connector plug?What are normal voltage/resistance readings for a good iacv?Is there a flow chart or proceedure for troubleshooting the valve to determine whether it is the valve or bad wiring or bad PCM? Code p1519 is set on my 2002 accord ex v6, and idle is inconsistent.Also, an image of the location of the iacv on the engine would be helpful.
Thanks!
Thanks!
vinspe
03-26-2014 03:16 PM
